I’m running Ubuntu 16.04 on the Intel aero compute board. I flashed the latest BIOS and FPGA as explained in 90 (References) OS user Installation · intel-aero/meta-intel-aero Wiki · GitHub
As for the flight controller, I followed the instruction on https://dev.px4.io/en/setup/building_px4.html to build the latest release:
git clone GitHub - PX4/PX4-Autopilot: PX4 Autopilot Software
cd Firmware
make aerofc-v1_default
make aerofc-v1_default upload
I connected both the LeddarOne and Px4flow with sonar to the telemetry port of the Intel Aero drone. The LeddarOne with tx and rx and the PX4flow to SDA and SCL.
Then, I connected to QGroundControl, performed airframe reset and full calibration. Everything worked fine, and I could get readings from the LeddarOne if I set the parameter SENS_LEDDAR1_CFG to 101, but not from the Px4flow because I didn’t added the driver in the file nuttx_aerofc-v1_default.cmake
Then, I added the line
drivers/px4flow
in the file nuttx_aerofc-v1_default.cmake and added the word AEROFC_V1 in the lines
if ver hwcmp PX4FMU_V2 PX4FMU_V4 PX4FMU_V4PRO MINDPX_V2 PX4FMU_V5 OMNIBUS_F4SD AEROFC_V1
then
px4flow start &
fi
of the file /Firmware/ROMFS/px4fmu_common/init.d/rcS, I compiled the code again and uploaded on the flight controller.
I connected to QGroundControl, I performed an airframe reset. I got correct readings from LeddarOne and Px4flow. The problem is that I got error while calibrating the inertial sensor of the drone. It said that:
[cal] calibration started: 2 mag
Mag 0 (ID 12) no matching uORB devid
[cal] calibration failed: mag
Thus, I cannot perform the calibration procedure.
I tried those steps on previous versions of the flight controller, for example:
cd Firmware
git tag -l
git checkout -b tags/v1.7.4beta
But the problem is still, that is I cannot calibrate the compass.
Finally, I tried with the firmware version cloned from GitHub - zehortigoza/PX4Firmware at stable-leddar_one
I added the px4flow driver enabled the px4driver at startup as I did before.
I connected to QGroundControl and I was finally able to get correct readings from LeddarOne (setting the parameter SENS_EN_LEDDAR1 to 1) and PX4flow and also to correctly calibrate the drone. Everything works fine.
However, this firmware version is 1.5.0 and I would be able to get the same work with a newer version. Any suggestion?
Thank you in advance,
Daniele
