Param changes are a good way of detecting things that perhaps need documentation.
For example COM_ARMABLE is new in v1.15 but there are no docs. Perhaps it should be added to Arm, Disarm, Prearm Configuration | PX4 Guide (main) though?
The list of params added/removed/default value changes are listed below:
Some of this may already have been documented
**EDIT - LIST Might include or omit a few things. Due to bug in JSON param generation these groups are not included in output so I get false positives. I have tried to clean up, but if there are any you can ignore them for now.
Geometry
ModalAI Custom Configuration
Payload Deliverer
RC
RC Input
Roboclaw
Roboclaw Driver
Rover Ackermann
Rover Differential Drive
Septentrio
UWB
UXRCE-DDS Client
Zenoh
[Bug] Param metadata missing for json and xml files · Issue #23442 · PX4/PX4-Autopilot · GitHub. I have tried to clean it up a bit.**
Removed in v1.15 and status unknown or maybe needs docs
[I’ve moved the things with “known” statuses down - eventually this should be empty]
Added in V1.15 and docs status unknown
[I’ve moved the things with docs or decision not to doc down - eventually this should be empty]
- ‘UAVCAN_SUB_GPS_R’,
Added and documented
Slow mode params
- ‘MC_SLOW_DEF_HVEL’, ‘MC_SLOW_DEF_VVEL’, ‘MC_SLOW_DEF_YAWR’, ‘MC_SLOW_MAP_HVEL’, ‘MC_SLOW_MAP_VVEL’, ‘MC_SLOW_MAP_YAWR’, ‘MC_SLOW_MIN_HVEL’, ‘MC_SLOW_MIN_VVEL’, ‘MC_SLOW_MIN_YAWR’,
Throw mode
Throw Launch (Multicopter) | PX4 Guide (main) (and in relnote)
- ‘COM_THROW_EN’, ‘COM_THROW_SPEED’,
Advanced config FW
‘FW_SERVICE_CEIL’, (used with) Advanced TECS Tuning (Weight and Altitude) | PX4 Guide (main)
‘VT_BT_TILT_DUR’ - already done VTOL Back-transition Tuning | PX4 Guide (main)
Safety updates
- COM_ARMABLE PX4 v115 docs around safety/arming params by hamishwillee · Pull Request #3308 · PX4/PX4-user_guide · GitHub
- COM_ARM_BAT_MIN PX4 v115 docs around safety/arming params by hamishwillee · Pull Request #3308 · PX4/PX4-user_guide · GitHub
- COM_DISARM_MAN PX4 v115 docs around safety/arming params by hamishwillee · Pull Request #3308 · PX4/PX4-user_guide · GitHub
- COM_FLTT_LOW_ACT PX4 v115 docs around safety/arming params by hamishwillee · Pull Request #3308 · PX4/PX4-user_guide · GitHub - (release note?)
- COM_WIND_MAX_ACT PX4 v115 docs around safety/arming params by hamishwillee · Pull Request #3308 · PX4/PX4-user_guide · GitHub - (release note?)
- FW_ACRO_YAW_EN’ PX4 v115 docs around safety/arming params by hamishwillee · Pull Request #3308 · PX4/PX4-user_guide · GitHub
- ‘MAN_KILL_GEST_T’, [v1.15] Kill gesture docs by hamishwillee · Pull Request #3316 · PX4/PX4-user_guide · GitHub
Distance sensors
- ‘SF1XX_MODE’,
Battery SIM
- ‘SIM_BAT_ENABLE’, - added to low battery in Simulate Failsafes | PX4 Guide (main)
USB0C
- ‘SYS_USB_AUTO’, - add to here: Serial Port Configuration | PX4 Guide (main)
Do nothing (much)
- ‘FW_AT_SYSID_F0’, ‘FW_AT_SYSID_F1’, ‘FW_AT_SYSID_TIME’, ‘FW_AT_SYSID_TYPE’,
- Ignore - you don’t need to know about them, though I did add link in Autotuning - link to params by hamishwillee · Pull Request #3322 · PX4/PX4-user_guide · GitHub
Because no one is showing any interest, and I believe them to be not something desrving of separate mention.
- ‘MPC_ACC_DECOUPLE’, - when would this be set?
- ‘MPC_YAWRAUTO_ACC’, - Does this need to be added to tuning docs or is it too rare to change?
- ‘RTL_APPR_FORCE’,
- @sfuhrer What’s a force approach landing?
- Is this for MC/FW or both?
- Important enough to add to param list in RTL docs such as Return Mode (Fixed-Wing) | PX4 Guide (main) ?
- ‘SENS_AFBR_HYSTER’, ‘SENS_AFBR_L_RATE’, ‘SENS_AFBR_MODE’, ‘SENS_AFBR_S_RATE’, ‘SENS_AFBR_THRESH’,
- All related to “AFBR Rangefinder”
- Could we get a docs page on this?
- Is that this AFBR-S50MV85G | 3D multipixel ToF sensor with \850 nm VCSEL ? Or are there variants?
- Are their wiring and setup instructions?
- Who would know?
- ‘SENS_EN_ASP5033’,
- We should generally track new sensors that are supported, particular those for drivers etc that can be inferred from folder locations etc.
- For this case we should add it to Airspeed Sensors | PX4 Guide (main) and take info from Modules Reference: Airspeed Sensor (Driver) | PX4 Guide (main)
- ‘SENS_IMU_CLPNOTI’,
- Presumably an event - should this be documented anywhere other than params? I.e. when would you change this?
Renames
- ‘FW_T_THR_DAMPING’, ‘FW_T_THR_INTEG’,
Removed and documented
Renamed to VOXL_ESC due to driver change (from note added below)
- ‘MODAL_IO_BAUD’, ‘MODAL_IO_CONFIG’, ‘MODAL_IO_MODE’, ‘MODAL_IO_RPM_MAX’, ‘MODAL_IO_RPM_MIN’, ‘MODAL_IO_SDIR1’, ‘MODAL_IO_SDIR2’, ‘MODAL_IO_SDIR3’, ‘MODAL_IO_SDIR4’, ‘MODAL_IO_T_COSP’, ‘MODAL_IO_T_DEAD’, ‘MODAL_IO_T_EXPO’, ‘MODAL_IO_T_MINF’, ‘MODAL_IO_T_PERC’, ‘MODAL_IO_VLOG’,
(you can use PX4_GZ_MODEL_POSE for position)
- ‘SIM_GZ_HOME_ALT’, ‘SIM_GZ_HOME_LAT’, ‘SIM_GZ_HOME_LON’,
-{‘CANNODE_NODE_ID’, - removed as was never used Cannode boot immediatly and get node ID later by AlexKlimaj · Pull Request #21270 · PX4/PX4-Autopilot · GitHub
Removed in Some parameter cleanup by sfuhrer · Pull Request #21736 · PX4/PX4-Autopilot · GitHub (not really used and not documented to start with):
- ‘COM_ARM_ARSP_EN’, VT_B_DEC_FF
These not doc’ed before so assume not needed to be doc’d now
- ‘FW_T_I_GAIN_THR’, - Renamed to FW_T_THR_INTEG in TECS throttle gains default reduction and transition values from previous PX4 version by sfuhrer · Pull Request #22548 · PX4/PX4-Autopilot · GitHub
- ‘FW_T_THR_DAMP’, - renamed FW_T_THR_DAMPING in TECS throttle gains default reduction and transition values from previous PX4 version by sfuhrer · Pull Request #22548 · PX4/PX4-Autopilot · GitHub
Navigator: Geofence improvements by sfuhrer · Pull Request #22394 · PX4/PX4-Autopilot · GitHub - removed not needed:
- ‘GF_ALTMODE’, ‘GF_COUNT’,
https://github.com/PX4/PX4-Autopilot/pull/22376
- ‘LNDMC_ALT_MAX’, Removed - GF_MAX_VER_DIST used instead
- ‘VT_TILT_SPINUP’ - Removed in Tiltrotor: move spin up tilt to control allocation by sfuhrer · Pull Request #21991 · PX4/PX4-Autopilot · GitHub
In release note
- ‘FW_ARSP_MODE’,
- ‘SYS_MC_EST_GROUP’ + ‘ATT_EN’, + ‘LPE_EN’,
- ‘SYS_HAS_NUM_ASPD’,
