January 29, 2020
Agenda
- Status update by component
- Open section for the community (Please add your agenda items)
- Anyone can propose topics for discussion
Join Meeting
Meeting ID: 946 175 205
Call in using your phone, find your local number: https://zoom.us/u/aetSYKbiMF
Component update
Documentation
- MAVSDK testing update: https://github.com/PX4/Devguide/pull/931
- Gitbook updates @hamishwillee ?
Flight Testing
- 96 flights
- PRs:
- https://github.com/PX4/Firmware/pull/13837
- https://github.com/PX4/Firmware/pull/13969
- https://github.com/PX4/Firmware/pull/14004
- https://github.com/PX4/Firmware/pull/13981 -> retesting
- https://github.com/PX4/Firmware/pull/13436 -> issues with Pixhawk 4, CUAV Mini
System Architecture
- Simplification of sensor pipeline -> single flow of data
- Calibration parameters applied later in sensors module
- (can also be temperature calibration)
- Work towards multiple estimators
- Revisit module base linked list: https://github.com/PX4/Firmware/pull/12191
OS / NuttX
- Upstreamed iMX RT
- Backported for now to merge
- Timer PR: @david_s5 reviewed it: beautiful, makes the RT configuration nicer: https://github.com/PX4/Firmware/pull/13871
Comms
- If
RADIO_STATUSis injected additional throttling was automatically configured and could lead to problems with non-SiK radios: https://github.com/PX4/Firmware/pull/14032- @david_s5: fmu-v5 Tx DMA is in, has that been tested end to end?
- new
OrbSubscriptionusage in mavlink module to review: https://github.com/PX4/Firmware/pull/14051
Driver
- See System Architecture above.
Commander
- Fixed preflight checks not
- @bkueng started nicer architecture for preflight checks
VTOL
- No update
Fixed Wing
- No update
Multicopter
- https://github.com/PX4/Firmware/pull/14017
- Rate control changes: @dagar ?
MAVROS / RTPS / ROS2
- Verification of dependencies for avoidance ->
- MAVROS SITL CI tests are now redundant.
- questions regarding dropping ROS
Avoidance
- No update
MAVSDK
- Release v0.24.0: changelog
Simulation
- https://github.com/PX4/sitl_gazebo/pull/393
- https://github.com/PX4/sitl_gazebo/pull/389
- https://github.com/PX4/sitl_gazebo/pull/400
- FastRTPs interface to be implemented with the Gazebo integration. To interface with Gazebo-ignition.
- https://github.com/PX4/Firmware/issues/14053
- CI: GitHub workflows build times have the same speed but scale even better than the Jenkins runners, and are nicely integrated, and maintained by GitHub, not by us.
- PX4IO sometimes broken on startup: https://github.com/PX4/Firmware/issues/13892
- Should we dumb PX4IO down so it’s just a pass-through failsafe device?
- Do we still need fixedwing manual mixing? Not sure. -> Rather parachute/abort for regulations.
- Maybe add developer mode with simple pass-through mode.
- Low latency cross-fire input to FMU.
- PWM outputs still need to be accessible for VTOL.
@LorenzMeier: UAVCAN node: what is required?
- Does it need direct RC interface or not?
- Startup of UAVCAN is late in sequence.
Errata and Feedback
