August 11, 2021
Join us
Agenda
- Community Q&A
- Roadmap
- High priority queue
- Release
- In-Depth discussions
Community Q&A
Raise your questions!
Peter Van Der Perk has proposed the PR here, which will need to wait for the Nuttx update not to have any conflicts.
Peter Van Der Perk: CMakeList update. As we go forward we can develop them according to each board.
Peter Van Der Perk proposed a global solution for all boards to develop the firmware which won’t be working cause of variables making problems sometimes.
@david_s5 mentioned an issue about the mag calibration with 1.12.1 with Pixhawk4 with the stock GPS module.
@david_s5 mentioned power indicator issue with QGC.
@rroche : SITL loses Datalink after 1.12 which initiates Failssafe action. The solution is to disable Failsafes
@aksuns has added this issue. PX4 relies on lockstep, disabling all will not make sense. Fusing errors on a specific IMU makes sense but not the entire system to be shut.
Holybro’s boards’ Thermal heater issue discussed. (The param to be set)
Roadmap
Discussion based on board: Roadmap · GitHub
High priority queue
Discussion based on board: High-Priority Queue · GitHub
Release
For smaller groups expanding technical discussions, stay until the end and follow up.
- QGC Daily releases are being uploaded manually.
