PX4 Dev Call: June 23, 2021
June 23, 2021
Join us
Agenda
  • Community Q&A
  • Roadmap
  • High priority queue
  • Release
  • In-Depth discussions
Community Q&A
  • Cristian Had his drone crashing while a colleague hovered it. It dropped straight down. Flight Review It can be seen from the log it can be seen that one UAVCAN ESC (Zubx Myxa) failed to follow the command mid-air. It saturates to full output command when it stops actuating and at the same time the reported rpm go to zero. So the drone lost altitude quickly. ICM20689 is the secondary with 16g and the others have more range.
  • Cristian is also seeing regular accel clipping reported on his secondary accelerometer on the Nora board. Could it be an accelerometer range configuration maybe even just for the clipping detection?
  • Vatsal Joshi wants to port PX4 to the Raspberry pi pico. He has NuttX working but doesn’t know everything else that’s needed for board support. He’ll join Slack to follow up on his questions. https://slack.px4.io/ will get fixed very soon.
Release
The only blocker for 1.12 is the PWM configuration
Roadmap
Discussion based on board: https://github.com/orgs/PX4/projects/25
High priority queue
Discussion based on board: https://github.com/orgs/PX4/projects/24
For smaller groups expanding technical discussions, stay until the end and follow up.
