PX4 Community Q&A: November 22, 2023
November 22, 2023
Join us
Agenda
  • Community Announcement
  • Community Q&A
  • General Discussions
:loudspeaker: Community Announcement
A.1 :
:people_holding_hands: Community Q&A (No deep technical discussions)
:exclamation: Guideline for asking a Question
  1. Specify what you are trying to achieve
  2. Specify what environment / platform you are using
  3. Prepare a Link or Document to help understand if possible
  4. First, ask the question on Discord or create a Github Issue!
  5. If you take over 5 minutes for the question, please continue in Discord or a Github Issue.
Q.1 : Multirotor hold having altitude oscillations when without Laser Range Finder - Alex
When Laser Range Finder (LRF) was not working, there were oscillations happening and altitude was not being kept.
Possible issue:
  • GPS data was not healthy
  • MPC Alt Mode was set to terrain hold, so maybe it goes to undefined state without LRF
Action Item: Will share log later (apparently flight review says it is corrupted and can’t open, but can open via PlotJuggler)
Q.2: Slow velocity horizontal behavior for multirotor not consistent after v1.13 - Sverre
Issue may not be fixed in v1.14, and on main it should be fixed - Matthias
https://github.com/PX4/PX4-Autopilot/commit/ff801fbc08e7b8453dd8c21768beceae591ea217
Relation to currently open PR:
https://github.com/PX4/PX4-Autopilot/pull/22102/files#diff-9aa90a2d3ce795bde10f2616d02754380f2004bbf9feec64586eb695bac18fc8R79
Q.3:
Signal strength reporting sensor data
Q.4: Custom board, but filesystem not working properly - Sangam Thampa
Daniel: Should check ‘defconfig’ file to chance the custom board dir value, like below
Q.5: SPI-only driver programming issue - Janardhan
  • Remove all I2C stuff, then failure shouldn’t happen
  • Also remove I2C stuff from the CMakeLists
The config pointer:
When I2C stuff is removed, results in error regarding I2C. So need to also remove that part as well.
Q.6: Docker container in Windows issue - Janardhan
Windows crashes when running the container.
  • Try WSL2 instead.
Q.7: Custom naming of USART ports - Janardhan
Use case: Want to change e.g. USART 1,2,3 into 0,1,2.
  • Currnetly NuttX configures so that USART ports get numbered automatically
  • Should be way to change NuttX config to change how serial numbering works out
Could be helpful:
:thinking: General Discussions
D.1 :
We have a large slow drone where we use a max velocity of 1m/s. After 1.13 we had to re-introduce smooth position control for the drone to work well at 1m/s. Are there any plans on making px4 compatible with slow drones?
