PX4 Dev Call: June 4, 2025 (Team sync, and Community Q&A)
PX4 Sync / Q&A - 2025-06-04T15:00:00Z
:tear_off_calendar: List of all Dronecode events
Agenda
  • Announcements
  • Future Events
  • Flight Testing Update
  • Release Discussion
  • Bug Report / Q&A
Announcements
:rocket: PX4 Release Testing
PX4 v1.16.0-rc1 is out, and we need your help with testing!
:warning: QGC v5.0.0-rc2 Alert
The QGC team expects a stable release next week! Please test and report issues now.
Next Dronecode Meetup
Nothing scheduled yet. If anyone is interested to host a Meetup please reach us out. Always happy to have it organized.
Future Events
About the Test Team
The team at Ascend Engineering (Chicago). are running flight testing for the community.
How to reach out to the team
  • GitHub: Tag user @PX4/testflights
  • Discord: #flight-testing
  • Weekly on the PX4 Dev Call
How to Request Testing (GitHub)
  • Write down the steps to test your issue/pull request
    • Make sure to note the risk involved in flying
    • Write down things to look out for / anticipate - eg: β€œwe are looking for no yaw jumps”
  • Add issue/pull request to the Flight Testing project board
  • Make sure to specify any hardware/software requirements as much as possible
Resources:
Comments / Discussion:
  • The flight testing team is building the VTOL
Release Discussion / Updates
v1.16 Release Discussion
:police_car_light: Release Candidate v1.16.0-rc1
The first release candidate for the upcoming release is finally available through github and QGC.
@rroche has prepared the draft of release notes which will be completed as the next RC is cut:
We need help with flight testing, especially for early adopters and users with free time who can provide logs from flights with their drones.
:test_tube: Release Testing
Testing Tracker
Issues Tracker
Community Q&A / PRs for Review
Q1: @stevejohn163 While flying the drone in Position mode using MANUAL_CONTROL joystick inputs, I want to temporarily override the yaw axis β€” for example, to automatically yaw the drone 90 degrees when a button is pressed. Is it possible to override the yaw input using a MAVLink message while still receiving manual joystick input via MANUAL_CONTROL? If so, which MAVLink message allows overriding specifically the yaw axis in Position mode?
Q2: @alexcekay What would be the possible way to save flash size for specific frames or board variant?
Discussed PRs:
  1. Fix reporting of connected battery by DonLakeFlyer Β· Pull Request #24800 Β· PX4/PX4-Autopilot Β· GitHub
    CC: @dagar ready to merge maybe?
  2. feat: configurable board pwm freq from Kconfig by Pedro-Roque Β· Pull Request #24787 Β· PX4/PX4-Autopilot Β· GitHub
  3. https://github.com/PX4/PX4-Autopilot/pull/24716
  4. 3dr_ctrl-zero-h7-oem-revg: Adding missing module which prevented the USB interface to start by TOTON95 Β· Pull Request #24938 Β· PX4/PX4-Autopilot Β· GitHub
Discussed Issues:
Question: While flying the drone in Position mode using MANUAL_CONTROL joystick inputs, I want to temporarily override the yaw axis β€” for example, to automatically yaw the drone 90 degrees when a button is pressed. Is it possible to override the yaw input using a MAVLink message while still receiving manual joystick input via MANUAL_CONTROL? If so, which MAVLink message allows overriding specifically the yaw axis in Position mode?
