When PPM is used, all channels are transmitted over one “cable” (including the signal (white or yellow), 5v (red), and ground pin (black)).
I assume when PPM is selected it will come out of channel 1 but I don’t know that. I have not used that hardware myself. If I was you I would try 1 and if it doesn’t work try the others too.
