Can I power the Pix32 from a 5v BEC vs. using a power module? Thinking I just need to
eliminate the power mod pre check in parameters?Just ordered a clone (Powerday) Pix32 to use as an antenna tracker to replace my current immersion module that is not compatible with MavLink. Trying to keep the number of individual components limited to keep things clean. I already have a 5v 20A BEC to drive the servos and want to power the Pix32 with it as well. Because it’s for a antenna tracker ground station, I don’t need or want any of the current monitoring features anyway.
