Hi champions,
I am building a rover using 2 wheelchairs powered by 24v acid battery, already have roboclaw 2x30, pixhawk4, telemetry…etc) please I am after recommendation to get a BEC to power the Pixhawk4.
Thank you
Hi @Jlsayed ,
The Pixhawk4 kit should come with a power module. If you need a smaller one, you can use https://shop.holybro.com/power-modulepm02_p1028.html
Hi Bresh,
sorry absolutely did not pay attention to it inside the box:roll_eyes: thanks a lot
quick check in the data sheet it could take up to 51 volt, will do my homework and make paper scratch for the wiring diagram and post it here for checking if you don’t mind…thank you
