Pixhawk 6X-RT Can't Connect to QGroundControl or NSH
Hi, I just bought the Pixhawk 6X-RT but I have some problems. Yesterday, it was fine connecting to QGroundControl and NSH, but the uxrce_dds_client modules didn’t start and I can’t find it on the system. So, I just flashed it again and enabled the uxrce_dds_client module. The problem is after I successfully flashed it, the Pixhawk doesn’t want to connect to the NSH through mavlink_shell.py or QGroundControl, but the device is still recognized by my OS. Any suggestions to help me ?
Hello guys I just found out the issue, turns out it was the firmware problem. When I upload the firmware from QgroundControl Daily Build (Master Branch px4_fmu-v6xrt_default). As far that I know, it is alpha version of 1.15, but when I built it from source with the same version, it still doesn’t work. Any help that possible solution for this booting problem ? Oh yea, the px4 always stuck on the bootloader and I dont know much about the bootloader.
I am having similar issues flashing these devices coming with an alpha firmware 1.15.alpha0, my QGroundControl broke indeed…
Yesterday I opened a ticket in the repo (qgroundcontrol/issues/11543) and contacted the flight controller manufacturer (HolyBro), no answers so far, but I will keep you posted…
