A PixHawk 4 mini was bought and first I load the Px4 Pro v1.8.2 Stable then I had some issues, afterwards I was told by holybro that 1.8.2 is not supported, that I shall use the "Developer Build (Master)" into the PixHawk 4 mini and then I loaded the version master and I have calibrated the sensors in Qgroundcontrol station
However when I try to arm the drone I get the following error:
Good day, what kind of gps + compass you have installed on your drone?
You can solve the issue disabling the compass but first you must find which one is external or internal, you can do this using the nsh console following this command :
type ? followed by enter
ls / obj (enter)
type : listener sensor_mag - 0
listener sensor_mag - 1
listener sensor_mag - 2
for every command there is the correspondent result: if its external you wil will find external, if not you will find false.
For disable the compass type in the search box, compass 0 or 1 or 2 or 3.
then, I calibrated the compass again, then I have also changed the
CBRK_IO_SAFETY = 22027
for the safety switch that is in the GPS.
I could armed the drone, and I did not have any errors:
But, well the questions here are:
What effect has in the real fly of the drone the fact that the sensor_mag1 has been disable.
Since the version Px4 Pro v1.8.2 Stable does not support the PixHawk 4 mini, and I have load the Developer Build (Master), but this version is for developers and not stable and it has not been try in real test yet.
Is it reliable to use this version for a real flight?
Good day,
in the Parameters tab just type CAL_MAG1_EN and disable it coz its the internal compass inside your fc, better use the external due the interferences you can have inside your fc. After every parameters you have modify test few hours the behavior of the drone.
Me i always install the master coz i have fully access to the parameters. Version 1.8.2 its already well tested
Well, as far I do understand you in the setup there are two compasses, one in the FCU (PeixHawk 4 mini) which is the internal and one in the GPS which is the external, right?
And,
Just using the external compass would be enough, right?
Well,
The V1.8.2 is already well tested and stable, but it does not work properly in the PixHawk 4 mini, so I am force to use the Master And I hope is stable enough for real flights :), is it?
the external compass is the one inside the gps. in my opinion better use the external so you will not have interferences like the compass in the fcu. The external is already enough.
Have a good flight…
Ok, thank you, I am planning to calibrate the drone again and then try a manual flight and then autonomous flight under mission mode and qgroundcontrol.
So, if in case I see the drone sluggish or twitchy and if PX4 I can not autotune the PID parameters, how can be done then.
I have a question.
I would like the drone to plan a trajectory and follow it in autonomous mode avoiding obstacles. And, somehow started using avoidance in gazebo+rviz for now. Then the idea is to translate the simulation into a real flight. What do you think? Is that a good option? or Is there another package?
I have re calibrated the drone and I have try some position flight mode and some mission plan mode with a small propellers so the drone wont fly yet and I got a warning:
The PixHawk 4 mini is on the top surface of the drone just over the center of gravity and the GPS comes with two sticks, one is 14 cm and the other one is 9 cm.
First, I positioned the GPS in front of the GPS at the distance of 6cm and at height of 14cm, then I changed the GPS to the lower stick which is 9cm height. And then I re calibrate the sensors again.
In a few words, the GPS on the top surface of the drone at horizontal distance from the pixhawk of 6cm and at height of 9cm.
I have tried to arm the drone again, in mission mode and manual mode but with small propellers so the drone did not fly and I still get the following issue:
When I arm the drone I get the following warnings:
- `GPS Horizontal Pos Drift too high`
- GPS Speed accuracy too law
the vehicle has failed to pre-arm
check in order to arm the vehicle
resolve the failure
I can see in the GPS status:
– GPS count 11
– GPS lock 3D GPS Lock
– HDOP 0.9
– VDOP 1.4
Do you have a clue how to solve these warnings?
USB 3 is known to be an effective GPS jamming source. The **jamming
indicator** should be around or below 40. Values around 80 or higher
are too high and the setup must be inspected.
And there is a new PX4 version V1.9 stable, which I load it and I re calibrate everything again, and I have also enabled the CAL_MAG1_EN
Then I have covered the GPS with aluminum paper as you can see it in the picture.
SENS_FLOW_ROT to 270 degrees, default
EKF2_AID_MASK to use optical flow and GPS
EKF2_HGT_MODE to use the range finder
The question is:
How can I check that the PX4FLOW sensor is working correctly together with the GPS ?
In other words, I guess that I shall get a position [xyz] that comes from the combination of both the GPS and the PX4FLOW , right?
So far I can see in the mavlink inspector the:
