I’m doing some detailed work with parameters right now and could use some input. I noticed that there are parameters in the full parameter reference that are not in the QGC list. For example this one.
CA9685_FUNC2 (INT32) PCA9685 Output Channel 2 Output Function
Comment: Select what should be output on PCA9685 Output Channel 2. The default failsafe value is set according to the selected function: - ‘Min’ for ConstantMin - ‘Max’ for ConstantMax - ‘Max’ for Parachute - (‘Max’+‘Min’)/2 for Servos - ‘Disarmed’ for the rest
Values:
- 0: Disabled
- 1: Constant Min
- 2: Constant Max
- 101: Motor 1
- 102: Motor 2
- 103: Motor 3
- 104: Motor 4
- 105: Motor 5
- 106: Motor 6
- 107: Motor 7
- 108: Motor 8
- 109: Motor 9
- 110: Motor 10
- 111: Motor 11
- 112: Motor 12
- 201: Servo 1
- 202: Servo 2
- 203: Servo 3
- 204: Servo 4
- 205: Servo 5
- 206: Servo 6
- 207: Servo 7
- 208: Servo 8
- 301: Offboard Actuator Set 1
- 302: Offboard Actuator Set 2
- 303: Offboard Actuator Set 3
- 304: Offboard Actuator Set 4
- 305: Offboard Actuator Set 5
- 306: Offboard Actuator Set 6
- 400: Landing Gear
- 401: Parachute
- 402: RC Roll
- 403: RC Pitch
- 404: RC Throttle
- 405: RC Yaw
- 406: RC Flaps
- 407: RC AUX 1
- 408: RC AUX 2
- 409: RC AUX 3
- 410: RC AUX 4
- 411: RC AUX 5
- 412: RC AUX 6
- 420: Gimbal Roll
- 421: Gimbal Pitch
- 422: Gimbal Yaw
I never noticed this parameter before so I think it may be new to PX4 1.13.3 which I am using. At any rate, what does this parameter do and when should I use it? Also, this parameter does not show up in the .params file that I downloaded from QGC,
Thanks,
Joe
