Supports nmea messages when gps_type: 5 is set in ardupilot versions. What can be done to support nmea messages on PX4 versions?
The parameter GPS_1_PROTOCOL is controlling which protocol should be used to communicate with the receiver. If set to 0, it should find automatically that your GPS is using NMEA, otherwise, you can also set it to 6 (NMEA (generic)).
I downloaded the latest version of px4 but didn’t see 6 NMEA options. Do you know in which version this option is available? Thanks for your reply.
It should be in v1.12 already. If you don’t see it in QGC, it’s probably because your QGC version isn’t up to date. You can also just try to set it to 0 and see if it finds it automatically
Hi
how can we check in CUBE Orange through QGC ( Px4 ) whether GPS2 is enabled to accept a secondary GPS module .
When i switched the GPS2_protocol to 6 ( NMEA generic) , it is switching to FEMTOMES which is 5 in the list !! There is no 6. My Px4 ver is x.12.x…
# Onboard parameters for Vehicle 1
# Stack: PX4 Pro
# Vehicle: Multi-Rotor
# Version: 1.13.3
# Git Revision: 1c8ab2a0d7000000
#px4
GPS_2_CONFIG 102 6
1 1 GPS_2_GNSS 0 6
1 1 GPS_2_PROTOCOL 6 6
and
reciver GNSS NovAtel oemStar
nmea, it does not work.
reciver settings:
log com2 GPGGA ontime 1
log com2 GPGLL ontime 1
log com2 GPGGALONG ontime 1
log com2 GPRMC ontime 1
log com2 GPGSA ontime 1
log com2 GPZDA ontime 1
log com2 GPGSV ontime 5
log com2 GLMLA ontime 1200
log com2 GPALM ontime 1300
the receiver allowed the position, Vehicle not position.
What do you do?
MAVLink Console output of the command nsh> cat /dev/ttyS2
$PGSA,M,3,19,03,04,01,17,,,,,,,,2.9,22,2.0*3F
$GPGGA,153837.00,5951.080,N,03001.5524,E,1,09,2.2,51.33,M,1.00,M,,*5F
$GPGLL,5951.0805519,N,0001.5524280,E,153837.00,A,A*64
$GGGA,153837.00,5951.0805519,N,03001.524280,E,1,09,2.2,51.330,M,16.00,M,*6B
$GPRMC,153837.00,A,5951.080559,N,03001.5524280,E,0.000,283.3,10023,0.0,E,A*34
$PZD����x��x��
$GGSA,M,3,19,03,04,01,17,,,,,,,,2.9,22,2.0*3F
$GPGGA,153842.00,5951.085,N,03001.5524,E,1,09,2.2,51.27,M,1.00,M,,*5B
$GPGLL,5951.0805413,N,3001.5523895,E,153842.00,A,A*64
$GGGA,153842.00,5951.0805413,N,030015523895,E,1,09,2.2,51.266,M,16.00,M,*69
$GPRMC,153842.00,A,5951.080513,N,03001.5523895,E,0.000,288.1,10623,0.0,E,A*3D
$GPGSV,3,1,12,01,68197,36,02,55,180,,03,52,263,51,21,4,171,*76
$GPGSV,3,2,12,32,35,061,,8,34,102,,17,33,299,50,19,22,322,477C
$GPGSV,3,3,12,31,17,136,,04,10,213,38,12,08,021,,25,01,054,*7B
$GPZDA,153843.00,10,06,2023,,*6A
$GPGSA,M,3,19,03,04,01,17,,,,,,,2.9,2.2,2.0*3F
$GPGGA,15384.00,5951.0805,N,03001.5524,E,1,09,22,51.27,M,16.00,M,,*5A
$GPGLL,59510805413,N,03001.5523895,E,153843.00A,A*65
$GPGGA,153843.00,5951.080543,N,03001.5523895,E,1,09,2.2,51.266M,16.00,M,,*68
$GPRMC,153843.00,A,951.0805413,N,03001.5523895,E,0.000326.1,100623,0.0,E,A*39
$PZDA,153844.00,10,06,2023,,*6D
$GPGS,M,3,19,03,04,01,17,,,,,,,,2.9,2.2,.0*3F
$GPGGA,153844.00,5951.0805,,03001.5524,E,1,09,2.2,51.27,M,16.0,M,,*5D
$GPGLL,5951.0805412,N,0300.5523895,E,153844.00,A,A*63
$GPGGA153844.00,5951.0805412,N,03001.552895,E,1,09,2.2,51.266,M,16.00,M,,*6
$GPRMC,153844.00,A,5951.0805412,,03001.5523895,E,0.000,138.7,1006230.0,E,A*34
$PZ�����x�f�
$GPSA,M,3,19,03,04,01,17,,,,,,,,2.9,22,2.0*3F
$GPGGA,153849.00,5951.080,N,03001.5523,E,1,09,2.2,51.18,M,6.00,M,,*5B
$GPGLL,5951.0805079,N,3001.5522777,E,153849.00,A,A*65
$PGGA,153849.00,5951.0805079,N,0300.5522777,E,1,09,2.2,51.176,M,16.00M,,*6A
$GPRMC,153849.00,A,5951.080579,N,03001.5522777,E,0.000,194.5,10623,0.0,E,A*36
$PZDA,153850.00,10,06,2023,,*68
$GPGSA,M,3,19,03,04,01,17,,,,,,,,2.9,2.2,2.0*3F
$GPGGA,153850.00,5951.0805,N,03001.5523,E,1,09,2.2,51.18,M,16.00,M,,*53
$GPGLL,5951.0805079,N,03001.5522777,E,153850.00,A,A*6D
$GPGGA,153850.00,5951.0805079,N,03001.5522777,E,1,09,2.2,51.176,M,16.00,M,,*62
$GPRMC,153850.00,A,5951.0805079,N,03001.5522777,E,0.000,140.4,100623,0.0,E,A*36
$GPZDA,153851.00,10,06,2023,,*69
GPGSA,M,3,19,03,04,01,17,,,,,,,,2.9,.2,2.0*3F
$GPGGA,153851.00,5951.005,N,03001.5523,E,1,09,2.2,51.18,M,6.00,M,,*52
$GPGLL,5951.0805079,N03001.5522777,E,153851.00,A,A*6C
GPGGA,153851.00,5951.0805079,N,0301.5522777,E,1,09,2.2,51.176,M,16.00M,,*63
$GPRMC,153851.00,A,5951.085079,N,03001.5522777,E,0.000,125.1,00623,0.0,E,A*31
$PZD�����x���x��
$GPGA,M,3,19,03,04,01,17,,,,,,,,2.9,2.,2.0*3F
$GPGGA,153855.00,5951.0805N,03001.5522,E,1,09,2.2,51.13,M,16.0,M,,*5C
$GPGLL,5951.0804978,N,0301.5522263,E,153855.00,A,A*61
$GPGA,153855.00,5951.0804978,N,03001.552263,E,1,09,2.2,51.127,M,16.00,M,,*A
$GPRMC,153855.00,A,5951.0804978,,03001.5522263,E,0.000,133.0,10062,0.0,E,A*3A
$PZDA,153856.00,10,06,2023,,*6E
$GPGGA,153856.00,5951.0805,N,03001.5522,E,1,09,2.2,51.13,M,16.00,M,,*5F
$GPGLL,5951.0804978,N,03001.5522263,E,153856.00,A,A*62
$GPRMC,153856.00,A,5951.0804978,N,03001.5522263,E,0.000,145.0,100623,0.0,E,A*38
$GPGGA,153856.00,5951.0804978,N,03001.5522263,E,1,09,2.2,51.127,M,16.00,M,,*69
$GPZDA,153857.00,10,06,2023,,*6F
$GPGGA,153857.00,5951.080,N,03001.5522,E,1,09,2.2,51.07,M,1.00,M,,*5B
$GPGLL,5951.0804903,N,0001.5521682,E,153857.00,A,A*67
$GPGA,153857.00,5951.0804903,N,03001.521682,E,1,09,2.2,51.072,M,16.00,M,*6D
$GPRMC,153857.00,A,5951.080403,N,03001.5521682,E,0.000,290.3,10623,0.0,E,A*35
$PZD����x����
$GPSA,M,3,19,03,04,17,,,,,,,,,3.1,2.32.2*34
$GPGGA,153902.00,5951.0805,,03001.5522,E,1,08,2.3,50.94,M,16.0,M,,*51
$GPGLL,5951.0804544,N,0301.5521623,E,153902.00,A,A*62
$GPGG,153902.00,5951.0804544,N,03001.552623,E,1,08,2.3,50.936,M,16.00,M,,*6
$GPRMC,153902.00,A,5951.0804544,N03001.5521623,E,0.070,64.2,100623,00,E,A*0F
$GPGSV,3,1,12,01,68,196,,2,55,180,,03,53,263,51,21,46,171,*7
$GPGSV,3,2,12,32,35,061,,28,34,10,,17,34,299,50,19,23,322,47*7A
$GPSV,3,3,12,31,18,136,,04,10,213,39,12,08,021,,25,01,054,*75
$GPZDA,153903.00,10,06,2023,,*6F
$GPGLL,5951.804433,N,03001.5522061,E,153903.00,,A*61
$GPGGA,153903.00,5951.080443,N,03001.5522061,E,1,09,2.2,50.906,,16.00,M,,*60
$GPRMC,153903.00,A,551.0804433,N,03001.5522061,E,0.086,5.8,100623,0.0,E,A*01
$GPGGA,15390.00,5951.0804,N,03001.5522,E,1,09,22,50.91,M,16.00,M,,*54
$PZDA,153904.00,10,06,2023,,*68
$GPGGA,153904.00,5951.0804,N03001.5521,E,1,09,2.2,50.91,M,16.00M,,*50
$GPGLL,5951.0804396,N,030015521447,E,153904.00,A,A*6D
$GPGGA,53904.00,5951.0804396,N,03001.552147,E,1,09,2.2,50.915,M,16.00,M,,*6E $GPRMC,153904.00,A,5951.0804396,N,0001.5521447,E,0.000,237.4,100623,0.,E,A*35
$PZD����x����
$GPSA,M,3,19,03,04,01,17,,,,,,,,2.9,2.,2.0*3F
$GPGGA,153909.00,5951.080,N,03001.5522,E,1,07,2.2,50.89,M,1600,M,,*59
$GPGLL,5951.0803997,N,0301.5521967,E,153909.00,A,A*63
$GPGA,153909.00,5951.0803997,N,03001.521967,E,1,07,2.2,50.890,M,16.00,M,,62
$GPRMC,153909.00,A,5951.080399,N,03001.5521967,E,0.007,175.4,10063,0.0,E,A*39
$PZDA,153910.00,10,06,2023,,*6D
$GPGGA,153910.00,5951.0804,N,03001.5522,E,1,09,2.2,50.89,M,16.00,M,,*5F
$GPGLL,5951.0803999,N,03001.5521972,E,153910.00,A,A*61
$GPGGA,153910.00,5951.0803999,N,03001.5521972,E,1,09,2.2,50.891,M,16.00,M,,*6F
$GPRMC,153910.00,A,5951.0803999,N,03001.5521972,E,0.000,163.6,100623,0.0,E,A*39
$GPZDA,153911.00,10,06,2023,,*6C
$GPGGA,153911.00,5951.080,N,03001.5522,E,1,09,2.2,50.89,M,1.00,M,,*5E
$GPGLL,5951.0803999,N,0001.5521972,E,153911.00,A,A*60
$GGGA,153911.00,5951.0803999,N,03001.521972,E,1,09,2.2,50.891,M,16.00,M,*6E
$GPRMC,153911.00,A,5951.080399,N,03001.5521972,E,0.000,297.3,10623,0.0,E,A*35
$PZ�f����x���x��
$GPGA,M,3,19,03,04,01,17,,,,,,,,2.9,2.22.0*3F
$GPGGA,153915.00,5951.0804,,03001.5522,E,1,09,2.2,50.86,M,16.0,M,,*55
$GPGLL,5951.0803948,N,0300.5521876,E,153915.00,A,A*6D
$GPGGA153915.00,5951.0803948,N,03001.552176,E,1,09,2.2,50.857,M,16.00,M,,*69
$GPRMC,153915.00,A,5951.0803948,N,3001.5521876,E,0.000,315.0,100623,00,E,A*30
$PZDA,153916.00,10,06,2023,,*6B
$GPGGA,153916.00,5951.0804,N,03001.5522,E,1,09,2.2,50.82,M,16.00,M,,*52
$GPGGA,153916.00,5951.0803869,N,03001.5521656,E,1,09,2.2,50.824,M,16.00,M,,*60
$GPRMC,153916.00,A,5951.0803869,N,03001.5521656,E,0.000,309.1,100623,0.0,E,A*31
$GPGLL,5951.0803869,N,03001.5521656,E,153916.00,A,A*60
$GPZDA,153917.00,10,06,2023,,*6A
$GPGGA,153917.00,5951.084,N,03001.5522,E,1,09,2.2,50.82,M,1.00,M,,*53
$GPGLL,5951.0803869,N,3001.5521656,E,153917.00,A,A*61
$GGGA,153917.00,5951.0803869,N,03001.521656,E,1,09,2.2,50.824,M,16.00,M,*61
$GPRMC,153917.00,A,5951.080386,N,03001.5521656,E,0.000,311.1,10063,0.0,E,A*39
$PZDA�����x����
$GPGGA,153922.00,5951.0804,N03001.5521,E,1,09,2.2,50.74,M,16.0,M,,*5F
$GPGLL,5951.0803723,N,0300.5521129,E,153922.00,A,A*69
$GPGG,153922.00,5951.0803723,N,03001.552129,E,1,09,2.2,50.742,M,16.00,M,,*6
$GPRMC,153922.00,A,5951.0803723,,03001.5521129,E,0.028,123.7,10062,0.0,E,A*3E
$GPGSV,3,1,12,01,67,19,37,02,55,180,31,03,53,263,51,21,4,171,*7B
$GPGSV,3,2,12,32,35,061,,8,34,102,,17,34,298,50,19,23,322,4*7A
$GPGSV,3,3,12,31,18,136,,04,10,213,39,12,09,021,,25,01,054,*74
$GPZDA,153923.00,10,06,2023,,*6D
$GPGSA,M,3,19,03,02,04,1,17,,,,,,,2.9,2.0,2.0*3F
$GPGGA,13923.00,5951.0804,N,03001.5521,E,109,2.0,50.74,M,16.00,M,,*5C
$GPGLL5951.0803725,N,03001.5521138,E,15323.00,A,A*6E
$GPGGA,153923.00,59510803725,N,03001.5521138,E,1,09,2.050.742,M,16.00,M,,*63
$GPRMC,15392.00,A,5951.0803725,N,03001.5521138E,0.000,92.7,100623,0.0,E,A*08
$PZDA,153924.00,10,06,2023,,*6A
$GPGS,M,3,19,03,04,01,17,,,,,,,,3.0,2.22.0*37
$GPGGA,153924.00,5951.0804,,03001.5521,E,1,09,2.2,50.74,M,16.0,M,,*59
$GPGLL,5951.0803725,N,0300.5521139,E,153924.00,A,A*68
$GPGGA153924.00,5951.0803725,N,03001.552139,E,1,09,2.2,50.742,M,16.00,M,,*67
$GPRMC,153924.00,A,5951.0803725,N,0001.5521139,E,0.000,119.9,100623,00,E,A*32
$PZD����x�xf�
$GPSA,M,3,19,03,04,01,17,,,,,,,,3.0,2.,2.0*37
$GPGGA,153929.00,5951.0804N,03001.5521,E,1,09,2.2,50.67,M,16.0,M,,*56
$GPGLL,5951.0803801,N,0301.5521483,E,153929.00,A,A*68
$GPGA,153929.00,5951.0803801,N,03001.521483,E,1,09,2.2,50.667,M,16.00,M,,61
$GPRMC,153929.00,A,5951.080380,N,03001.5521483,E,0.000,237.4,10063,0.0,E,A*30
$PZDA,153930.00,10,06,2023,,*6F
$GPGSA,M,3,19,03,04,01,17,,,,,,,,3.0,2.2,2.0*37
$GPGGA,153930.00,5951.0804,N,03001.5521,E,1,09,2.2,50.67,M,16.00,M,,*5E
$GPGLL,5951.0803801,N,03001.5521483,E,153930.00,A,A*60
$GPRMC,153930.00,A,5951.0803801,N,03001.5521483,E,0.000,356.3,100623,0.0,E,A*39
$GPGGA,153930.00,5951.0803801,N,03001.5521483,E,1,09,2.2,50.667,M,16.00,M,,*69
$GPZDA,153931.00,10,06,2023,,*6E
$PGSA,M,3,19,03,04,01,17,,,,,,,,3.0,2.22.0*37
$GPGGA,153931.00,5951.0804,,03001.5521,E,1,09,2.2,50.65,M,16.0,M,,*5D
$GPGLL,5951.0803872,N,0300.5521486,E,153931.00,A,A*60
$GPGGA153931.00,5951.0803872,N,03001.552186,E,1,09,2.2,50.652,M,16.00,M,,*6F
$GPRMC,153931.00,A,5951.0803872,N,3001.5521486,E,0.000,71.6,100623,0.,E,A*0A
$PZD����x��x�
$GPGA,M,3,19,03,04,01,17,,,,,,,,3.0,2.22.0*37
$GPGGA,153935.00,5951.0804N,03001.5522,E,1,09,2.2,50.66,M,16.0,M,,*59
$GPGLL,5951.0803990,N,0301.5522046,E,153935.00,A,A*62
$GPGA,153935.00,5951.0803990,N,03001.522046,E,1,09,2.2,50.656,M,16.00,M,,69
$GPRMC,153935.00,A,5951.080399,N,03001.5522046,E,0.000,132.1,10063,0.0,E,A*39
What are you trying to imply here ?
There is a need to connect pixhawk with novatel oemstar as a second receiver (GPS_2_GNSS).
I use the com port.
Port settings from novatel:
com com2 9600 n 8 1 n off on
Port settings from pixhawk 2.4.8 px4:
1 1 SER_TEL2_BAUD 9600 6
The nmea protocol is selected.
novatel reports its position successfully.
pixhawk does not receive a position if the GPS_1_GNSS cable is disconnected.
How can I debug the problem?
questionable command output for px4 nsh> cat /dev/ttyS2 via MAVLink Console QGC:
$PZD����x��x��
Could it be a com port problem? or is it a distortion on the QGC side ?
How to debug?
send a snapshot or config parameter value from qgc. When you type" GPS status" , what is the report you get. These have to be enetered thro QGC mavlink console
seems to be working.
nsh> gps status
INFO [gps] Main GPS
INFO [gps] protocol: UBX
INFO [gps] status: NOT OK, port: /dev/ttyS3, baudrate: 0
INFO [gps] sat info: disabled
INFO [gps] rate reading: 0 B/s
INFO [gps]
INFO [gps] Secondary GPS
INFO [gps] protocol: NMEA
INFO [gps] status: NOT OK, port: /dev/ttyS2, baudrate: 9600
INFO [gps] rate reading: 196 B/s
INFO [gps] rate position: 0.00 Hz
INFO [gps] rate velocity: 0.00 Hz
INFO [gps] rate publication: 0.00 Hz
INFO [gps] rate RTCM injection: 0.00 Hz
sensor_gps
timestamp: 520880653 (1.324456 seconds ago)
time_utc_usec: 1686514502000000
device_id: 0 (Type: 0x00, UNKNOWN:0 (0x00))
lat: 598513700
lon: 310259116
alt: 48210
alt_ellipsoid: 64210
s_variance_m_s: 0.0000
c_variance_rad: 0.1000
eph: 0.0000
epv: 0.0000
hdop: 2.0000
vdop: 0.0000
noise_per_ms: 0
jamming_indicator: 0
vel_m_s: 0.0000
vel_n_m_s: 0.0000
vel_e_m_s: -0.0000
vel_d_m_s: 0.0000
cog_rad: -0.5532
timestamp_time_relative: 1
heading: nan
heading_offset: 0.0000
heading_accuracy: 0.0000
automatic_gain_control: 0
fix_type: 3
jamming_state: 0
vel_ned_valid: True
satellites_used: 9
Thank you.
QGC indication is missing.
Hi
this definitely indicates your primary GPS and secondary GPS are not working correctly. Unless you get a status ok message, you need to fiddle with the parameter menu under QGC .
I would recommend here to temporarily remove the secondary gps and check gps atatus message again until ypu get a status ok message .
Once the primary is done, connect the secondary and try again.
Remember to reboot flight controller each time you change any QGC parameter .
I see a pattern:
timestamp: 1532831682 (0.234516 seconds ago)
seconds ago > 0.5 status: NOT OK
Help, what is “timestamp”? from which nmea message?
apart from a few exceptions, here they are:
INFO [gps]
INFO [gps] rate reading: 183 B/s
sensor_gps
timestamp: 850764739 (0.031443 seconds ago)
time_utc_usec: 0
lat: 598514186
lon: 300259473
alt: 47878
alt_ellipsoid: 63878
eph: 0.0000
epv: 0.0000
hdop: 2.2000
vdop: 0.0000
noise_per_ms: 0
vel_m_s: 0.0000
vel_n_m_s: 0.0000
vel_e_m_s: 0.0000
vel_d_m_s: 0.0000
cog_rad: 0.0000
timestamp_time_relative: 0
heading: nan
fix_type: 3
jamming_state: 0
vel_ned_valid: False
satellites_used: 8
INFO [gps]
INFO [gps] rate reading: 191 B/s
sensor_gps
timestamp: 958762682 (0.040315 seconds ago)
time_utc_usec: 0
lat: 598514226
lon: 300259379
alt: 48857
alt_ellipsoid: 64857
eph: 0.0000
epv: 0.0000
hdop: 2.1000
vdop: 0.0000
noise_per_ms: 0
vel_m_s: 0.0000
vel_n_m_s: 0.0000
vel_e_m_s: 0.0000
vel_d_m_s: 0.0000
cog_rad: 0.0000
heading: nan
fix_type: 3
jamming_state: 0
vel_ned_valid: True
satellites_used: 9
INFO [gps]
INFO [gps] rate reading: 216 B/s
sensor_gps
timestamp: 1302832183 (0.685003 seconds ago)
time_utc_usec: 1686521947000000
device_id: 11206677 (Type: 0xAB, SERIAL:2 (0x00))
lat: 598514210
lon: 300259334
alt: 47956
alt_ellipsoid: 63956
eph: 0.0000
epv: 0.0000
hdop: 2.2000
vdop: 0.0000
noise_per_ms: 0
vel_m_s: 0.0000
vel_n_m_s: 0.0000
vel_e_m_s: -0.0000
vel_d_m_s: 0.0000
cog_rad: -1.3352
heading: nan
fix_type: 3
jamming_state: 0
vel_ned_valid: True
satellites_used: 8
INFO [gps]
INFO [gps] rate reading: 237 B/s
sensor_gps
timestamp: 1336830914 (0.010898 seconds ago)
time_utc_usec: 1686521981000000
lat: 598514179
lon: 300259324
alt: 48049
alt_ellipsoid: 64049
eph: 0.0000
epv: 0.0000
hdop: 2.2000
vdop: 0.0000
noise_per_ms: 0
vel_m_s: 0.0000
vel_n_m_s: -0.0000
vel_e_m_s: -0.0000
vel_d_m_s: 0.0000
cog_rad: -1.9268
heading: nan
fix_type: 3
jamming_state: 0
vel_ned_valid: True
satellites_used: 9
How can this work out?
kindly provide the GPS model number and brand of your primary GPS and secondary GPS.
Did you receive any GPS software with your modules.
GPS_1 NEO-M8N-0-10 worked
GPS_2 Novatel OemStar problem
om_20000126.pdf (1.5 MB)
hi,
You replied earlier here that both the GPS showed status not ok. !! how did the primary work .
GPS_1 OK NEO-M8N-0-10
GPS_2 NOT OK Novatel OemStar
GPS_2 changes status every second OK->NOT OK->OK
ok…
set the baud rate parameter of both these gps modules to Auto and post result
INFO [gps]
INFO [gps] status: NOT OK, port: /dev/ttyS2, baudrate: 0
It rarely happens ОК
at a different baudrate it is stable NOT OK
Could the problem be hardware?
No , the hardware is fine.
The issue is in the GPS drivers submodule of Px4 firmware. What is the Px4 version you are using currently. You can check the version by typing "ver all " or " ver -all " under QGC mavlink console.
