Hi @Dman ,
If you armed, you should be able to get a log file from the SD card (or download it from QGC). Please upload it to logs.px4.io and share the link here.
Also, can you specify what’s your hardware and type of drone please? Are your ESCs using PPM, OneShot, DShot?
If the outputs are 900usec, it usually means that the vehicle is not armed or that the mixer is not loaded properly or that you are not measuring the correct output. Are you connected to the main outputs? Did you disable IO? Did you follow that guide https://docs.px4.io/master/en/config_mc/racer_setup.html ?
