Hello Guys,
drone ran in manual mode, then I used QGC switched to orbit mode. It was working fine initially, after a period of time it suddenly crash. need your help to diagnose. thank you!
frame H380
controller pixhawk4 / M8N
telemetry 3DR v1.9
motor 2212/1400kv
ESC blheli 35A
link for crash log
https://logs.px4.io/plot_app?log=85562b85-4847-4a29-8791-6a2ed820fa11
Sorry to hear about your crash.
From the log it looks like that at time 3:43.200 presumably some ESC/motor/propeller(s) failed and it could not correct attitude and altitude anymore with only 3 outputs.
Does that match what you observed or found later? Can you do a test if fall motors still work?
Hi Julian,
Thanks for the input.
Yes, found a wire was disconnected between motor and ESC. I soldered to connect each other after came back home, but I can’t make sure which motor was, should be either motor 2 or motor 3.
motor 3 motor 1
pixhawk ^ (^ means direction)
motor 2 motor 4
Hi. Do you have a log of that flight (.bin file)? I’m running a program in my Doctor’s Thesis and it will be very useful. My e-mail is joaolmarins@gmail.com
If you have other files of good flights i’ll also appreciatte.
Thanks.
