I’m building the tailsitter based on Arkbird frame.
I use Pixhawk 2 (2.4.8).
The firmware is 1.9.2, configured with Capitoshka airframe.
I’m testing it on the ground, and need some advices.
- The Pixhawk is calibrated according to the FW mode, is it correct?
- When the plane is armed, and the battery is connected via the power module, there are no outputs on servos or motors (connected to the Main outputs).
- On the flight tab of the Qgroundcontrol, the attitude ball is always according to the FW mode, even when i switch to the VTOL with the RC.
- When the Pixhawk is powered from battery, i can’t connect to the Qgroundcontrol application with the USB cable.
Appreciate any help.
