Motor Rototing Slowely after giving full Throttle
I am using the Pixhawk 6X flight controller and the Tekko F32 4-in-1 ESC to run the motors. I have changed the protocol to DShot600 in Pixhawk, made all the necessary adjustments, and calibrated the ESCs. After completing the calibration, I tested the motors. However, even at 100% throttle, the motors are rotating very slowly.
Additionally, I am using the Paladin EV Transmitter and the FGr12B Receiver. Can anyone help me resolve this issue?
Ensure the battery voltage matches the required input for your motors and ESC.
And can you share logs?
I try to upload it, but it’s showing an error-only PDF, JPEG File Format is only supported, like that’s showing
thank for your response.
You can open param list in txt. or notebad and copy the hole list in to word or google docs and then save it as PDF same can be done with logs.
I already downloaded the Fil InTelemetry Log Format How can i change to PDF
you can also upload your log file here and then share the link: https://logs.px4.io/
Did the issue resolved???
