I am running px4 V1.11.3 on a cube orange in conjunction with two external magnetometers (model: HERE 3). Before the magnetometer calibration I set the following parameters:
CAL_MAG1_ID = 8944899
CAL_MAG1_EN = 1
CAL_MAG2_ID = 8944643
CAL_MAG2_EN = 0
CAL_MAG_PRIME = 8944899
8944643 is located inside the fuelage very close to the power cables so I want to disable it and use 8944899 instead as the primary magnetometer. But I intend to use the device’s GPS antenna so that is why it should be part of the system.
After calibrating the magnetometers and rebooting, the parameters change by mistake. This is the result:
CAL_MAG1_ID = 8944643
CAL_MAG1_EN = 1
CAL_MAG2_ID = 8944899
CAL_MAG2_EN = 0
CAL_MAG_PRIME = 8944643
The magnetometer 8944643 that I disabled becomes enabled and becomes the primary magnetometer. The magnetometer that I enabled (8944899) gets disabled.
Can anybody help me with that issue? Thanks!
