Hi
is possible to access error messages somewhere in log?
In Qgroundcontrol, during the flight, error mesage apper ( [lpe] gps fault 0 0 219 0 0 0, or another numbers) but in log I did not see any problems with GPS. Is possible to see error mesages in logs, to be able precisely found moment when error happens, and determine cause of problems.
Now I found in QGC history LPE GPS error came up in 9:36:10 and 9:36:54
What can cause this type of fault? log shows that all the time GPS have 9-10 sat, what shut be enough
A GPS fault happens when the GPS measurements jump more than the position uncertainy/GPS measurement uncertainty allow. This usually happens in poor GPS conditions, such as when a siginificant part of the sky is occluded or in scenarios with severe multipath effects.
The health of the sensors is published to the estimator_status topic here:
thanks for answer
I flight on the free space, so I will try to change GPS position on copter, if it helps.
Will be nice to have some graph in logmuncher, where will be shown if some sensor or application does not failing.
Because it will be more difficult to find problem without connected QGroundControl
David
I try some more fligts, I move GPS to by above batery.
Grounstation continue with warning of GPS nosy and LPE GPS error. But from logs are not visible any problems.
The are clerly visible, when is system switch to the position mode, copter start diverge from desired position.
I try to switch to EKF2 here is log http://logs.uaventure.com/view/HWKKrTyuyAfNiJaySyX3nh
jumps in the position visible on the map are not real(copter stay only close to start point), estimator have very big error when position mode is on.
System is reporting that is something wrong with GPS, but Im at open field, GPS is on the hieghes position on copter and I try two diferent modules, so Im out of ideas what I can try.
I see magnetometer measurements are very nosy, because I using internal mag on pixracer, only few mm above power board (ASCP4). I can try connect external mag from GPS module. Is it possible that mags make kalman gains messy?
Have someone any idea what can be wrong? Or what can I try?
Thaks
David
