After take off PX4 loses global and local positioning?
Hey all,
I have a problem where after take-off my quad loses global and local positioning and descends back to the ground. I consistently got this problem until one time before the battery died the drone cooperated for ~50sec and then it landed with a low battery fail safe.
This made me think that the power board/current is somehow affecting the flight controller or gps?
I moved the GPS ~2in higher and placed a copper tape barrier between the power board and the flight controller. The GPS jamming dropped significantly but I still have the same problem.
Here is the log of a typical failed flight, with the copper barrier.
https://logs.px4.io/plot_app?log=dae498e7-4254-4b03-9c99-94ecd897e0a7
And this is the log of the one and only successful flight until the battery died.
https://logs.px4.io/plot_app?log=2b0bb5b5-5daf-44cf-929f-72266cbd5908
Hardware:
  • Flight Controller: Pixracer R15 over wifi ESP8266
  • GPS: taoglas mRo
I’m really out of my depth being a software developer and would really appreciate someone with experience to have a look at my logs :smiley:
Thank you.
There could be 101 reasons why that could happened. You can buy one of those GPS stick that raises the antenna about 4 inches above.
Have you checked what is the frequency you are using is it jamming your signal?
Are you doing this indoor?
Is there anything magnetic around your antenna that might causes interference?
How about power? When it flew, are you supplying sufficient power to power your motors and your gps and flight controller? Is your flight controller kept resetting or in sufficient to supply power to the GPS?
How about wiring? Is it loose when it flies and vibration causing disruption to power to the gps or connection to gps?
Hi @Joseph_Lim
I appreciate your help, most of your questions are answered in the description and possibly in the log files attached.
I am having trouble reading the logs as I’m a novice to all this :frowning:
If you have experience in log reading and have the time it would be great if you could quickly check over them. Something might pop out as an obvious problem to you?
