Hello there, been trying to make this work for a while now.
General idea:
- Launch a drone (typhoon) and a ground robot (turtlebot) in the same gazebo world
- Move the turtlebot in gazebo via keyboard teleop
- The drone would follow the turtlebot based on the FollowMe module
Im currently stuck at launching the typhoon and turtlebot in the same gazebo world!
I followed the documentation here and eddited my launch files as follows:
The multi_uav_mavros_sitl.launch:
<launch>
<!-- vehicle model and world -->
<arg name="est" default="ekf2"/>
<arg name="vehicle" default="iris"/>
<arg name="world" default="$(find mavlink_sitl_gazebo)/worlds/empty.world"/>
<!-- gazebo configs -->
<arg name="gui" default="true"/>
<arg name="debug" default="false"/>
<arg name="verbose" default="false"/>
<arg name="paused" default="false"/>
<!-- Gazebo sim -->
<include file="$(find gazebo_ros)/launch/empty_world.launch">
<arg name="gui" value="$(arg gui)"/>
<arg name="world_name" value="$(arg world)"/>
<arg name="debug" value="$(arg debug)"/>
<arg name="verbose" value="$(arg verbose)"/>
<arg name="paused" value="$(arg paused)"/>
</include>
<!-- UAV0 -->
<group ns="uav0">
<!-- MAVROS and vehicle configs -->
<arg name="ID" value="0"/>
<arg name="fcu_url" default="udp://:14540@localhost:14580"/>
<!-- PX4 SITL and vehicle spawn -->
<include file="$(find px4)/launch/dev_single_vehicle_spawn.launch">
<arg name="x" value="0"/>
<arg name="y" value="0"/>
<arg name="z" value="0"/>
<arg name="R" value="0"/>
<arg name="P" value="0"/>
<arg name="Y" value="0"/>
<arg name="vehicle" value="$(arg vehicle)"/>
<arg name="mavlink_udp_port" value="14560"/>
<arg name="mavlink_tcp_port" value="4560"/>
<arg name="ID" value="$(arg ID)"/>
</include>
<!-- MAVROS -->
<include file="$(find mavros)/launch/px4.launch">
<arg name="fcu_url" value="$(arg fcu_url)"/>
<arg name="gcs_url" value=""/>
<arg name="tgt_system" value="$(eval 0 + arg('ID'))"/>
<arg name="tgt_component" value="1"/>
</include>
</group>
<group ns="turtlebot">
<arg name="ID" value="1"/>
<include file="$(find turtlebot3_gazebo)/launch/turtlebot3_empty_world.launch">
<arg name="model" default="burger"/>
<arg name="x_pos" default="1.0"/>
<arg name="y_pos" default="0.0"/>
<arg name="z_pos" default="0.0"/>
</include>
</group>
The turtlebot3_empty_world.launch is edited as follows:
<launch>
<arg name="x_pos" default="0.0"/>
<param name="robot_description" command="$(find xacro)/xacro --inorder $(find turtlebot3_description)/urdf/turtlebot3_$(arg model).urdf.xacro" />
<node pkg="gazebo_ros" type="spawn_model" name="spawn_urdf" args="-urdf -model turtlebot3_$(arg model) -x $(arg x_pos) -y $(arg y_pos) -z $(arg z_pos) -param robot_description" />
</launch>`
Both robots are spawned and im able to control/takeoff with the drone. However, the turtlebot is unresponsive to the keyboard teleop node, moreover as soon as it is spawned it just seems to go in circles at a steady and slow speed (with or without teleop)…
I was told here on github that i would need a seperate working directory as shown here #12482
- If i understand #12482 correctly there should be a different working directory for each spawned vehicle, and to do that I have to add an argument as noted in this line
<node name="sitl_$(arg ID)" pkg="px4" type="px4" output="screen" args="$(find px4)/ROMFS/px4fmu_common -s etc/init.d-posix/rcS -i $(arg ID) -w sitl_$(arg vehicle)_$(arg ID) $(arg px4_command_arg1)">
in the launch/single_vehicle_spawn.launch file?
Moreover for the above to work, the changes for platforms/posix/src/main.cpp have to be pulled too?
- As for the rCS file, I was under the impression that its needed only for other px4 vehicles? Since turtlebot is not using parameters such as
mavlink_udp_portSITL_UDP_PRTfcu_urldo i still need that rCS file? If so, then i need to include values of these parameters in the<group ns="turtlebot">part of launch file?
Thanks for the feedback!
