Hello! I have a small 5in drone, running Kakute H7 1.3 with PX4 v1.13.2.
I connected an external GPS with magnetometer - Holybro M8N.
I have aligned the arrow on the GPS and on Kakute, they both point forwards.
I have calibrated all the sensors, and I got unusable Position control mode, with lots of whirpooling etc.
So I did a little bit of investigation, and it seems that with the default rotation parameters: ACC_ROT and GYRO_ROT are Internal, MAG0_ROT is no_rotation, the compass is very much misaligned.
I did some testing and comparisons with working compass on my phone, and I figured that if I set CAL_MAG0_ROT to: Pitch 180°, Yaw 270°, the compass is aligned, I can fly in Position mode normally with no issues or whirpooling.
Why is that? I use the same M8N with other drones running Pixhawk 6C/6X with the same FW version, and none have this issue.
