Hi All.
First thnx for all info found on this forum. Its our first build with Px4 and Cube. Before we always used DJI.
I tried to search the Arducopter and Px4 forum to see any other use of a fan in enclosed builds. Only found 1 post on the Arducopter forum.
I’m building a large (25-30kg) hex with Cube Blue and Kore board full enclosed so it would be weatherproof. i’m a bit worried that the Kore board will overheat. It is build with air vents (In-out) in the bottom plate and would like to use a Brush-less 4mm fan (with low pass filter) to cool the Kore board and Fpv video transmitter. I don’t know if it is necessary to use a fan. To my knowledge the Kore board does not have temp sensors only the Cube has.
Do i need to use the baro from the Here 2 Gps or does the baro from the Cube run reliable in this situation?
How do i determine in the log if the baro in the Cube is usable?
Thnx for any help on this and let me know if i can supply more info.
Edit; Build is almost done. will post log with and without fan running
