I have configured the xml file quadrotor for nano size but sometingis off
I am creating the quadrotor nano flight for jsbsim. I have configured model xml file by follow. When trigger take off it started acting weird. Should I need to consider anything else or did i made a mistake in calculation ..
<?xml version="1.0"?> <?xml-stylesheet type="text/xsl" href=" http://jsbsim.sourceforge.net/JSBSim.xsl "?>
<fdm_config xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” name=“quad_nano” version=“2.0”
release=“ALPHA” xsi:noNamespaceSchemaLocation=“http://jsbsim.sourceforge.net/JSBSim.xsd”>
<author>Akila</author>
<filecreationdate>2026-05-07</filecreationdate>
<version>1.0</version>
<description>Quad Nano based directly on working dflyer</description>
<wingarea unit="M2">0.005</wingarea>
<wingspan unit="M">0.08</wingspan>
<chord unit="M">0.08</chord>
<htailarea unit="FT2">0.0</htailarea>
<htailarm unit="FT">0.0</htailarm>
<vtailarea unit="FT2">0.0</vtailarea>
<vtailarm unit="FT">0.0</vtailarm>
<location name="AERORP" unit="M">
  <x>0.0</x>
  <y>0.0</y>
  <z>0.0</z>
</location>
<location name="EYEPOINT" unit="M">
  <x>0.0</x>
  <y>0.0</y>
  <z>0.0</z>
</location>
<location name="VRP" unit="M">
  <x>0.0</x>
  <y>0.0</y>
  <z>0.0</z>
</location>
<mass_balance>
<ixx unit="KG\*M2">0.00045</ixx>
<iyy unit="KG\*M2">0.00045</iyy>
<izz unit="KG\*M2">0.00080</izz>
<emptywt unit="KG">0.040</emptywt>
</mass_balance>
<ground_reactions>
<contact type="STRUCTURE" name="front_left_base">
  <location unit="M">
    <x>0.03</x>
    <y>0.03</y>
    <z>-0.01</z>
  </location>
  <static_friction>20</static_friction>
  <dynamic_friction>6</dynamic_friction>
  <spring_coeff unit="N/M">20</spring_coeff>
  <damping_coeff unit="N/M/SEC">6</damping_coeff>
</contact>
<contact type=“STRUCTURE”
  name="front_right_base">
  <location unit="M">
    <x>0.03</x>
    <y>-0.03</y>
    <z>-0.01</z>
  </location>
</contact>
  name="rear_left_base">
  <location unit="M">
    <x>-0.03</x>
    <y>0.03</y>
    <z>-0.01</z>
  </location>
</contact>
  name="rear_right_base">
  <location unit="M">
    <x>-0.03</x>
    <y>-0.03</y>
    <z>-0.01</z>
  </location>
</contact>
</ground_reactions>
<property value="0.0">fcs/esc-cmd-norm\[0\]</property>
<property value="0.0">fcs/esc-cmd-norm\[1\]</property>
<property value="0.0">fcs/esc-cmd-norm\[2\]</property>
<property value="0.0">fcs/esc-cmd-norm\[3\]</property>
<channel name="Motor_0">
  <actuator name="fcs/etc/esc_0">
    <input>fcs/esc-cmd-norm\[0\]</input>
    <clipto>
      <min>0.0</min>
      <max>1.0</max>
    </clipto>
    <output>fcs/esc-out\[0\]</output>
  </actuator>
</channel>
<channel name="Motor_1">
  <actuator name="fcs/etc/esc_1">
    <input>fcs/esc-cmd-norm\[1\]</input>
    <clipto>
      <min>0.0</min>
      <max>1.0</max>
    </clipto>
    <output>fcs/esc-out\[1\]</output>
  </actuator>
</channel>
<channel name="Motor_2">
  <actuator name="fcs/etc/esc_2">
    <input>fcs/esc-cmd-norm\[2\]</input>
    <clipto>
      <min>0.0</min>
      <max>1.0</max>
    </clipto>
    <output>fcs/esc-out\[2\]</output>
  </actuator>
</channel>
<channel name="Motor_3">
  <actuator name="fcs/etc/esc_3">
    <input>fcs/esc-cmd-norm\[3\]</input>
    <clipto>
      <min>0.0</min>
      <max>1.0</max>
    </clipto>
    <output>fcs/esc-out\[3\]</output>
  </actuator>
</channel>
<property value="0.0">fcs/torque_bypass</property>
<property value="0.0">fcs/motor_torque\[0\]</property>
<channel name="Motor_0_Torque">
  <fcs_function>
    <function>
      <product>
        <table>
          <independentVar>fcs/esc-out\[0\]</independentVar>
          <tableData>
            0.0   0.0
            0.25  0.01
            0.5   0.02
            0.75  0.03
            1.0   0.04
          </tableData>
        </table>
        <value>1</value>
      </product>
    </function>
    <output>fcs/motor_torque\[0\]</output>
  </fcs_function>
</channel>
<property value="0.0">fcs/motor_torque\[1\]</property>
<channel name="Motor_1_Torque">
  <fcs_function>
    <function>
      <product>
        <table>
          <independentVar>fcs/esc-out\[1\]</independentVar>
          <tableData>
            0.0   0.0
            0.25  0.01
            0.5   0.02
            0.75  0.03
            1.0   0.04
          </tableData>
        </table>
        <value>1</value>
      </product>
    </function>
    <output>fcs/motor_torque\[1\]</output>
  </fcs_function>
</channel>
<property value="0.0">fcs/motor_torque\[2\]</property>
<channel name="Motor_2_Torque">
  <fcs_function>
    <function>
      <product>
        <table>
          <independentVar>fcs/esc-out\[2\]</independentVar>
          <tableData>
            0.0   0.0
            0.25  0.01
            0.5   0.02
            0.75  0.03
            1.0   0.04
          </tableData>
        </table>
        <value>-1</value>
      </product>
    </function>
    <output>fcs/motor_torque\[2\]</output>
  </fcs_function>
</channel>
<property value="0.0">fcs/motor_torque\[3\]</property>
<channel name="Motor_3_Torque">
  <fcs_function>
    <function>
      <product>
        <table>
          <independentVar>fcs/esc-out\[3\]</independentVar>
          <tableData>
            0.0   0.0
            0.25  0.01
            0.5   0.02
            0.75  0.03
            1.0   0.04
          </tableData>
        </table>
        <value>-1</value>
      </product>
    </function>
    <output>fcs/motor_torque\[3\]</output>
  </fcs_function>
</channel>
<property value="0.0">fcs/net_torque</property>
<channel name="Motor_Net_Torque">
  <fcs_function>
    <function>
      <sum>
        <property>fcs/motor_torque\[0\]</property>
        <property>fcs/motor_torque\[1\]</property>
        <property>fcs/motor_torque\[2\]</property>
        <property>fcs/motor_torque\[3\]</property>
      </sum>
    </function>
    <output>fcs/net_torque</output>
  </fcs_function>
</channel>
<external_reactions>
<property value="0.0">fcs/esc-out\[0\]</property>
<property value="0.0">fcs/esc-out\[1\]</property>
<property value="0.0">fcs/esc-out\[2\]</property>
<property
  value="0.0">fcs/esc-out\[3\]</property>
<property value="0.0">fcs/lift_bypass\[0\]</property>
<property value="0.0">fcs/lift_bypass\[1\]</property>
<property
  value="0.0">fcs/lift_bypass\[2\]</property>
<property value="0.0">fcs/lift_bypass\[3\]</property>
<property value="1.0">fcs/motor_health\[0\]</property>
<force
  name="MOTOR_0_LIFT" frame="BODY">
  <function>
    <sum>
      <product>
        <table>
          <tableData>
            0.0   0.0
            0.25  0.04
            0.5   0.08
            0.75  0.12
            1.0   0.18
          </tableData>
        </table>
        <value>1</value>
        <property>fcs/motor_health\[0\]</property>
      </product>
      <property>fcs/lift_bypass\[0\]</property>
    </sum>
  </function>
  <location unit="M">
    <x>0.03</x>
    <y>0.03</y>
    <z>0.0</z>
  </location>
  <direction>
    <x>0.0</x>
    <y>0.0</y>
    <z>-1.0</z>
  </direction>
  <output>aero/motor_lift\[0\]</output>
</force>
<force name="MOTOR_1_LIFT" frame="BODY">
  <function>
    <sum>
      <product>
        <table>
          <tableData>
            0.0   0.0
            0.25  0.04
            0.5   0.08
            0.75  0.12
            1.0   0.18
          </tableData>
        </table>
        <value>1</value>
      </product>
      <property>fcs/lift_bypass\[1\]</property>
    </sum>
  </function>
  <location unit="M">
    <x>-0.03</x>
    <y>-0.03</y>
    <z>0.0</z>
  </location>
  <direction>
    <x>0.0</x>
    <y>0.0</y>
    <z>-1.0</z>
  </direction>
  <output>aero/motor_lift\[1\]</output>
</force>
<force name="MOTOR_2_LIFT" frame="BODY">
  <function>
    <sum>
      <product>
        <table>
          <tableData>
            0.0   0.0
            0.25  0.04
            0.5   0.08
            0.75  0.12
            1.0   0.18
          </tableData>
        </table>
        <value>1</value>
      </product>
      <property>fcs/lift_bypass\[2\]</property>
    </sum>
  </function>
  <location unit="M">
    <x>0.03</x>
    <y>-0.03</y>
    <z>0.0</z>
  </location>
  <direction>
    <x>0.0</x>
    <y>0.0</y>
    <z>-1.0</z>
  </direction>
  <output>aero/motor_lift\[2\]</output>
</force>
<force name="MOTOR_3_LIFT" frame="BODY">
  <function>
    <sum>
      <product>
        <table>
          <tableData>
            0.0   0.0
            0.25  0.04
            0.5   0.08
            0.75  0.12
            1.0   0.18
          </tableData>
        </table>
        <value>1</value>
      </product>
      <property>fcs/lift_bypass\[3\]</property>
    </sum>
  </function>
  <location unit="M">
    <x>-0.03</x>
    <y>0.03</y>
    <z>0.0</z>
  </location>
  <direction>
    <x>0.0</x>
    <y>0.0</y>
    <z>-1.0</z>
  </direction>
  <output>aero/motor_lift\[3\]</output>
</force>
</external_reactions>
<axis name="DRAG">
  <function name="aero/force/drag">
    <product>
      <property>aero/qbar-psf</property>
      <property>metrics/Sw-sqft</property>
      <value>1.0</value>
    </product>
  </function>
</axis>
<axis name="ROLL" />
<axis name="PITCH" />
<axis name="YAW">
  <function name="aero/moment/yaw">
    <property>fcs/net_torque</property>
  </function>
</axis>
</fdm_config>
