Custom OmniX boat SITL
Hello, I have been designing an omniX boat, and I am sure that the control allocation is not problematic. I am preparing to simulate the Mission mode in SITL, and my custom model has successfully run in Gazebo. After the armed, I can see the propellers rotating, but the boat does not move. I suspect that the libgazebo_usv_dynamics_plugin I am using might not be suitable or the parameters might not be set correctly. Can you advise me on how to debug the simulation environment? @Jaeyoung-Lim
This is my sdf file:
<sdf version='1.6'>
  <model name='omnix_boat'>
    <link name='base_link'>
      <pose frame=''>0 0 0 0 -0 0</pose>
      <inertial>
        <mass>0.90444</mass>
        <inertia>
          <ixx>0.0061404</ixx>
          <ixy>1.5992e-06</ixy>
          <ixz>5.1716e-07</ixz>
          <iyy>0.0061403</iyy>
          <iyz>-1.4898e-08</iyz>
          <izz>0.011554</izz>
        </inertia>
      </inertial>
      <collision name='base_link_collision'>
        <geometry>
          <mesh>
            <scale>1 1 1</scale>
            <uri>model://fish_detector/meshes/base_link.STL</uri>
          </mesh>
        </geometry>
      </collision>
      <visual name='base_link_visual'>
        <geometry>
          <mesh>
          </mesh>
        </geometry>
      </visual>
    </link>
    <joint name='imu_joint' type='revolute'>
      <pose frame='base_link'>0 0 0 0 0 0</pose>
      <parent>base_link</parent>
      <child>imu_link</child>
      <axis>
        <xyz>1 0 0</xyz>
        <limit>
          <lower>0</lower>
          <upper>0</upper>
          <effort>0</effort>
          <velocity>0</velocity>
        </limit>
        <dynamics>
          <spring_reference>0</spring_reference>
          <spring_stiffness>0</spring_stiffness>
        </dynamics>
      </axis>
    </joint>
    <link name='imu_link'>
      <pose>0 0 0 0 -0 0</pose>
      <inertial>
        <pose>0 0 0 0 0 0</pose>
        <mass>0.05</mass>
        <inertia>
          <ixx>2.2917e-08</ixx>
          <ixy>0</ixy>
          <ixz>0</ixz>
          <iyy>2.2917e-08</iyy>
          <iyz>0</iyz>
          <izz>-4.1667e-08</izz>
        </inertia>
      </inertial>
      <visual name='imu_link_visual'>
        <geometry>
          <mesh>
            <uri>model://fish_detector/meshes/imu_link.STL</uri>
          </mesh>
        </geometry>
      </visual>
    </link>
    <link name='motor1_link'>
      <pose frame=''>0.1293 0.14604 -0.007 0 0 -0.7854</pose>
      <inertial>
        <mass>0.04548</mass>
        <inertia>
          <ixx>7.1618e-06</ixx>
          <ixy>3.2424e-08</ixy>
          <ixz>-4.7703e-07</ixz>
          <iyy>1.2249e-05</iyy>
          <iyz>7.1728e-10</iyz>
          <izz>1.1362e-05</izz>
        </inertia>
      </inertial>
      <collision name='motor1_link_collision'>
        <geometry>
          <mesh>
            <uri>model://fish_detector/meshes/motor1_link.STL</uri>
          </mesh>
        </geometry>
      </collision>
      <visual name='motor1_link_visual'>
        <geometry>
          <mesh>
          </mesh>
        </geometry>
      </visual>
    </link>
    <joint name='motor1_joint' type='revolute'>
      <child>motor1_link</child>
      <axis>
        <xyz>1 0 0</xyz>
        <limit>
          <lower>-1e+16</lower>
          <upper>1e+16</upper>
        </limit>
        <dynamics>
        </dynamics>
        <use_parent_model_frame>0</use_parent_model_frame>
      </axis>
    </joint>
    <link name='motor2_link'>
      <pose frame=''>0.1293 -0.14604 -0.007 0 -0 0.7854</pose>
      <inertial>
        <inertia>
          <iyz>7.1729e-10</iyz>
        </inertia>
      </inertial>
      <collision name='motor2_link_collision'>
        <geometry>
          <mesh>
            <uri>model://fish_detector/meshes/motor2_link.STL</uri>
          </mesh>
        </geometry>
      </collision>
      <visual name='motor2_link_visual'>
        <geometry>
          <mesh>
          </mesh>
        </geometry>
      </visual>
    </link>
    <joint name='motor2_joint' type='revolute'>
      <child>motor2_link</child>
      <axis>
        <xyz>1 0 0</xyz>
        <limit>
        </limit>
        <dynamics>
        </dynamics>
      </axis>
    </joint>
    <link name='motor3_link'>
      <pose frame=''>-0.14604 0.1293 -0.007 0 -0 0.7854</pose>
      <inertial>
        <inertia>
          <iyz>7.1731e-10</iyz>
        </inertia>
      </inertial>
      <collision name='motor3_link_collision'>
        <geometry>
          <mesh>
            <uri>model://fish_detector/meshes/motor3_link.STL</uri>
          </mesh>
        </geometry>
      </collision>
      <visual name='motor3_link_visual'>
        <geometry>
          <mesh>
          </mesh>
        </geometry>
      </visual>
    </link>
    <joint name='motor3_joint' type='revolute'>
      <child>motor3_link</child>
      <axis>
        <xyz>1 0 0</xyz>
        <limit>
        </limit>
        <dynamics>
        </dynamics>
      </axis>
    </joint>
    <link name='motor4_link'>
      <pose frame=''>-0.14604 -0.1293 -0.007 0 0 -0.7854</pose>
      <inertial>
        <inertia>
          <iyz>7.173e-10</iyz>
        </inertia>
      </inertial>
      <collision name='motor4_link_collision'>
        <geometry>
          <mesh>
            <uri>model://fish_detector/meshes/motor4_link.STL</uri>
          </mesh>
        </geometry>
      </collision>
      <visual name='motor4_link_visual'>
        <geometry>
          <mesh>
          </mesh>
        </geometry>
      </visual>
    </link>
    <joint name='motor4_joint' type='revolute'>
      <child>motor4_link</child>
      <axis>
        <xyz>1 0 0</xyz>
        <limit>
        </limit>
        <dynamics>
        </dynamics>
      </axis>
    </joint>
    <include>
      <uri>model://gps</uri>
      <pose>0 0 0.06 0 0 0</pose>
      <name>gps</name>
    </include>
    <joint name='gps_joint' type='fixed'>
      <child>gps::link</child>
    </joint>
    <plugin name='gazebo_imu_plugin' filename='libgazebo_imu_plugin.so'>
      <robotNamespace></robotNamespace>
      <linkName>imu_link</linkName>
      <imuTopic>/imu</imuTopic>
      <gyroscopeNoiseDensity>0.0003394</gyroscopeNoiseDensity>
      <gyroscopeRandomWalk>3.8785e-05</gyroscopeRandomWalk>
      <gyroscopeBiasCorrelationTime>1000.0</gyroscopeBiasCorrelationTime>
      <gyroscopeTurnOnBiasSigma>0.0087</gyroscopeTurnOnBiasSigma>
      <accelerometerNoiseDensity>0.004</accelerometerNoiseDensity>
      <accelerometerRandomWalk>0.006</accelerometerRandomWalk>
      <accelerometerBiasCorrelationTime>300.0</accelerometerBiasCorrelationTime>
      <accelerometerTurnOnBiasSigma>0.196</accelerometerTurnOnBiasSigma>
    </plugin>
    <plugin name='magnetometer_plugin' filename='libgazebo_magnetometer_plugin.so'>
      <robotNamespace/>
      <pubRate>100</pubRate>
      <noiseDensity>0.0004</noiseDensity>
      <randomWalk>6.4e-06</randomWalk>
      <biasCorrelationTime>600</biasCorrelationTime>
      <magTopic>/mag</magTopic>
    </plugin>
    <plugin name='barometer_plugin' filename='libgazebo_barometer_plugin.so'>
      <robotNamespace/>
      <pubRate>200</pubRate>
      <baroTopic>/baro</baroTopic>
    </plugin>
    <static>0</static>
    <plugin name='motor1_model' filename='libgazebo_motor_model.so'>
      <reversible>true</reversible>
      <jointName>motor1_joint</jointName>
      <linkName>motor1_link</linkName>
      <turningDirection>cw</turningDirection>
      <timeConstantUp>0.0125</timeConstantUp>
      <timeConstantDown>0.025</timeConstantDown>
      <maxRotVelocity>2100</maxRotVelocity>
      <motorConstant>8.54858e-03</motorConstant>
      <momentConstant>0.01</momentConstant>
      <commandSubTopic>/gazebo/command/motor_speed</commandSubTopic>
      <motorNumber>0</motorNumber>
      <rotorDragCoefficient>0.000806428</rotorDragCoefficient>
      <rollingMomentCoefficient>1e-06</rollingMomentCoefficient>
      <motorSpeedPubTopic>/motor_speed/0</motorSpeedPubTopic>
      <rotorVelocitySlowdownSim>10</rotorVelocitySlowdownSim>
    </plugin>
    <plugin name='motor2_model' filename='libgazebo_motor_model.so'>
      <jointName>motor2_joint</jointName>
      <linkName>motor2_link</linkName>
      <motorNumber>1</motorNumber>
      <motorSpeedPubTopic>/motor_speed/1</motorSpeedPubTopic>
    </plugin>
    <plugin name='motor3_model' filename='libgazebo_motor_model.so'>
      <jointName>motor3_joint</jointName>
      <linkName>motor3_link</linkName>
      <motorNumber>2</motorNumber>
      <motorSpeedPubTopic>/motor_speed/2</motorSpeedPubTopic>
    </plugin>
    <plugin name='motor4_model' filename='libgazebo_motor_model.so'>
      <jointName>motor4_joint</jointName>
      <linkName>motor4_link</linkName>
      <motorNumber>3</motorNumber>
      <motorSpeedPubTopic>/motor_speed/3</motorSpeedPubTopic>
    </plugin>
    <plugin name='usv_dynamics_wamv_dynamics_plugin' filename='libgazebo_usv_dynamics_plugin.so'>
      <bodyName>base_link</bodyName>
      <waterLevel>0</waterLevel>
      <waterDensity>997.8</waterDensity>
      <xDotU>0.0</xDotU>
      <yDotV>0.0</yDotV>
      <nDotR>0.0</nDotR>
      <xU>51.3</xU>
      <xUU>0.0</xUU>
      <yV>102.6</yV>
      <yVV>0.0</yVV>
      <zW>450.0</zW>
      <kP>50.0</kP>
      <mQ>50.0</mQ>
      <nR>400.0</nR>
      <nRR>0.0</nRR>
      <hullRadius>0.213</hullRadius>
      <boatWidth>0.4</boatWidth>
      <boatLength>0.4</boatLength>
      <length_n>2</length_n>
      <wave_model>ocean_waves</wave_model>
    </plugin>
    <plugin name='mavlink_interface' filename='libgazebo_mavlink_interface.so'>
      <robotNamespace/>
      <imuSubTopic>/imu</imuSubTopic>
      <magSubTopic>/mag</magSubTopic>
      <baroSubTopic>/baro</baroSubTopic>
      <mavlink_addr>INADDR_ANY</mavlink_addr>
      <mavlink_tcp_port>4560</mavlink_tcp_port>
      <mavlink_udp_port>14560</mavlink_udp_port>
      <serialEnabled>0</serialEnabled>
      <serialDevice>/dev/ttyACM0</serialDevice>
      <baudRate>57600</baudRate>
      <qgc_addr>INADDR_ANY</qgc_addr>
      <qgc_udp_port>14550</qgc_udp_port>
      <sdk_addr>INADDR_ANY</sdk_addr>
      <sdk_udp_port>14540</sdk_udp_port>
      <hil_mode>0</hil_mode>
      <hil_state_level>0</hil_state_level>
      <send_vision_estimation>0</send_vision_estimation>
      <send_odometry>1</send_odometry>
      <enable_lockstep>0</enable_lockstep>
      <use_tcp>1</use_tcp>
      <motorSpeedCommandPubTopic>/gazebo/command/motor_speed</motorSpeedCommandPubTopic>
      <control_channels>
        <channel name="rotor1">
          <input_index>0</input_index>
          <input_offset>0</input_offset>
          <input_scaling>100</input_scaling>
          <zero_position_disarmed>0</zero_position_disarmed>
          <zero_position_armed>0</zero_position_armed>
          <joint_control_type>velocity</joint_control_type>
          <joint_name>motor1_joint</joint_name>
        </channel>
        <channel name="rotor2">
          <input_index>1</input_index>
          <joint_name>motor2_joint</joint_name>
        </channel>
        <channel name="rotor3">
          <input_index>2</input_index>
          <joint_name>motor3_joint</joint_name>
        </channel>
        <channel name="rotor4">
          <input_index>3</input_index>
          <joint_name>motor4_joint</joint_name>
        </channel>
      </control_channels>
    </plugin>
  </model>
</sdf>
