I’m a newbie and I want to make a drone with thermal camera. Then I’m planning to get the value of the highest temparature.
I want to use flir lepton 3.5 with this project. Is it compatible with pixhawk if not can you suggest a thermal camera that can be used in distance?
And is it possible to get the highest value of the highest temperature with pixhawk?
Flir lepton 3.5 => https://www.flir.com/products/lepton/?model=500-0771-01&vertical=microcam&segment=oem
