Hi Guys,
Is there a way to disable the external compas without disconnecting it?
Regards,
pturcotte
Hi Guys,
Regards,
pturcotte
I can’t test but if in QGC you put CAL_MAG1_ID at 0, I think that will turn off the external compas. (I not sure so if you fly be careful
Can I ask you why do you want to disable it ?
Vivien
I want to disable it because I am using an external compas (HCM5883) and it is not Temperature compensated like the ones in the PixRacer…
I will test it soon, regards,
pturcotte
Only concern at the moment (after clearing it to 0) it complains about “PREFLIGHT FAIL: MAG 1 MAG 1 UNCALIBRATED”…
Is there a way skip this check?
Regards,
pturcotte
