According to the Pixhawk servo motor video tutorial,
I find that the safety button on GPS does not work for mine.
I need to switch the SF button, which is set as ARM/DISARM.
Then, I can move the servo motors.
I want to set up the initial position of servo motors to grasp something, but
it is inconvenient to require ARM (SF button) which will makes all rotors rotate.
Can I control servo motors through FrSky controller directly without safety (ARM/DISARM protection)?
I search online and find similar video
Pixhawk Servos NOT Working? - How to Arm WITHOUT a Safety Switch
that
Use BRD_SAFETY_MASK
to set which individual channels remain enabled with the safety switch.
However, the parameter cannot be found in QGroundControl
