Do the PixHawk 6C systems battery monitor connection take a 6S input?
Hi @Rmorojr,
I have built a few heavy lift airframes recently. As far as you use the Power Modules (PM02 v3 or PM06 or similar) that support the voltage and current sensing at higher voltages, you should be fine. Some PMs sense voltage up to 6S and some up to 14S. There is also Analog and digital sensing among these modules. Link to the products : Power Modules & PDBs – Holybro Store [Holybro Power Module]
