Hi i am QGC 4.2.6 VER. user.
When i see the mission that i made, i can only recognize one take off point
But when i tried to fly and arming it changed double. So i can recognize two take off point.
Can you explain what is this phenomenon
And does it affect to flight if i take off in this position.
I assume what happens is you’ve placed a home position manually in your mission. Then when you arm it will update with actual GPS location to the home position as reported by the GPS.
Perhaps that particular behavior has changed in later version. (I’m using 4.2.8)
