Hello all,
I have been struggling to get the Standard VTOL HITL work properly on fresh Ubuntu 20.04.
When the simulation starts, the aircraft exists at the gazebo window
At Qgroundcontrol, I am having some errors
I can ARM and FLY manually in STABILIZED mode by using the virtual joysticks
The Mission mode cannot be engaged
Anybody has any idea how to solve this issue?
SOME BACKGROUND INFORMATION
I applied the toolchain installation as per described here.
I follow the HIL instructions as below:
COMMAND-1:
ozan@Ozan-Ubuntu:~/Desktop/PX4_HITL/PX4-Autopilot$ DONT_RUN=1 make px4_sitl_default gazebo
-- PX4 version: v1.11.0-rc3-2110-ge9370c658a
-- PX4 config file: /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/boards/px4/sitl/default.cmake
-- PX4 config: px4_sitl_default
-- PX4 platform: posix
-- PX4 lockstep: enabled
-- cmake build type: RelWithDebInfo
-- The CXX compiler identification is GNU 9.3.0
-- The C compiler identification is GNU 9.3.0
-- The ASM compiler identification is GNU
-- Found assembler: /usr/bin/cc
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Building for code coverage
-- ccache enabled (export CCACHE_DISABLE=1 to disable)
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.8.5", minimum required is "3")
-- build type is RelWithDebInfo
-- PX4 ECL: Very lightweight Estimation & Control Library v1.9.0-rc1-548-g6f2dec7
-- ROMFS: ROMFS/px4fmu_common
-- Configuring done
-- Generating done
-- Build files have been written to: /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/build/px4_sitl_default
[0/818] git submodule src/drivers/gps/devices
[1/818] git submodule src/lib/ecl
[5/818] git submodule mavlink/include/mavlink/v2.0
[14/818] git submodule Tools/sitl_gazebo
[21/818] Performing configure step for 'sitl_gazebo'
-- install-prefix: /usr/local
-- Performing Test COMPILER_SUPPORTS_CXX17
-- Performing Test COMPILER_SUPPORTS_CXX17 - Success
-- Performing Test COMPILER_SUPPORTS_CXX14
-- Performing Test COMPILER_SUPPORTS_CXX14 - Success
-- Performing Test COMPILER_SUPPORTS_CXX11
-- Performing Test COMPILER_SUPPORTS_CXX11 - Success
-- Performing Test COMPILER_SUPPORTS_CXX0X
-- Performing Test COMPILER_SUPPORTS_CXX0X - Success
-- Using C++17 standard
-- Found Boost: /usr/lib/x86_64-linux-gnu/cmake/Boost-1.71.0/BoostConfig.cmake (found suitable version "1.71.0", minimum required is "1.58") found components: system thread filesystem
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.1")
-- Checking for module 'bullet>=2.82'
-- Found bullet, version 2.88
-- Found ccd: /usr/include (found suitable version "2.0", minimum required is "2.0")
-- Found fcl: /usr/include (found suitable version "0.5.0", minimum required is "0.3.2")
-- Found assimp: /usr/include (found version "5.0.0")
-- Found DART: /usr/include (Required is at least version "6.6") found components: dart
-- Found Boost: /usr/lib/x86_64-linux-gnu/cmake/Boost-1.71.0/BoostConfig.cmake (found suitable version "1.71.0", minimum required is "1.40.0") found components: thread system filesystem program_options regex iostreams date_time
-- Found Protobuf: /usr/lib/x86_64-linux-gnu/libprotobuf.so;-lpthread (found version "3.6.1")
-- Looking for ignition-math6 -- found version 6.7.0
-- Searching for dependencies of ignition-math6
-- Looking for OGRE...
-- OGRE_PREFIX_WATCH changed.
-- Checking for module 'OGRE'
-- Found OGRE, version 1.9.0
-- Found OGRE: optimized;/usr/lib/x86_64-linux-gnu/libOgreMain.so;debug;/usr/lib/x86_64-linux-gnu/libOgreMain.so
-- Looking for OGRE_Paging...
-- Found OGRE_Paging: optimized;/usr/lib/x86_64-linux-gnu/libOgrePaging.so;debug;/usr/lib/x86_64-linux-gnu/libOgrePaging.so
-- Found OGRE_Terrain: optimized;/usr/lib/x86_64-linux-gnu/libOgreTerrain.so;debug;/usr/lib/x86_64-linux-gnu/libOgreTerrain.so
-- Found OGRE_Property: optimized;/usr/lib/x86_64-linux-gnu/libOgreProperty.so;debug;/usr/lib/x86_64-linux-gnu/libOgreProperty.so
-- Found OGRE_RTShaderSystem: optimized;/usr/lib/x86_64-linux-gnu/libOgreRTShaderSystem.so;debug;/usr/lib/x86_64-linux-gnu/libOgreRTShaderSystem.so
-- Looking for OGRE_Volume...
-- Found OGRE_Volume: optimized;/usr/lib/x86_64-linux-gnu/libOgreVolume.so;debug;/usr/lib/x86_64-linux-gnu/libOgreVolume.so
-- Found OGRE_Overlay: optimized;/usr/lib/x86_64-linux-gnu/libOgreOverlay.so;debug;/usr/lib/x86_64-linux-gnu/libOgreOverlay.so
-- Looking for ignition-transport8 -- found version 8.2.0
-- Searching for dependencies of ignition-transport8
-- Found Protobuf: /usr/lib/x86_64-linux-gnu/libprotobuf.so;-lpthread (found suitable version "3.6.1", minimum required is "3")
-- Config-file not installed for ZeroMQ -- checking for pkg-config
-- Checking for module 'libzmq >= 4'
-- Found libzmq , version 4.3.2
-- Found ZeroMQ: TRUE (Required is at least version "4")
-- Checking for module 'uuid'
-- Found uuid, version 2.34.0
-- Found UUID: TRUE
-- Looking for ignition-msgs5 -- found version 5.7.0
-- Searching for dependencies of ignition-msgs5
-- Checking for module 'tinyxml2'
-- Found tinyxml2, version 6.2.0
-- Looking for ignition-common3 -- found version 3.11.1
-- Searching for dependencies of ignition-common3
-- Looking for dlfcn.h - found
-- Looking for libdl - found
-- Found DL: TRUE
-- Searching for <ignition-common3> component [graphics]
-- Looking for ignition-common3-graphics -- found version 3.11.1
-- Searching for dependencies of ignition-common3-graphics
-- Looking for ignition-fuel_tools4 -- found version 4.3.0
-- Searching for dependencies of ignition-fuel_tools4
-- Found CURL: /usr/lib/x86_64-linux-gnu/libcurl.so (found version "7.68.0")
-- Checking for module 'jsoncpp'
-- Found jsoncpp, version 1.7.4
-- Found JSONCPP: TRUE
-- Checking for module 'yaml-0.1'
-- Found yaml-0.1, version 0.2.2
-- Found YAML: TRUE
-- Checking for module 'libzip'
-- Found libzip, version 1.5.1
-- Found ZIP: TRUE
-- Checking for one of the modules 'glib-2.0'
-- Found OpenCV: /usr (found version "4.2.0")
-- Found TinyXML: /usr/lib/x86_64-linux-gnu/libtinyxml.so
-- Checking for module 'gstreamer-1.0 >= 1.0'
-- Found gstreamer-1.0 , version 1.16.2
-- Checking for module 'gstreamer-base-1.0 >= 1.0'
-- Found gstreamer-base-1.0 , version 1.16.2
-- Found GStreamer: GSTREAMER_INCLUDE_DIRS;GSTREAMER_LIBRARIES;GSTREAMER_VERSION;GSTREAMER_BASE_INCLUDE_DIRS;GSTREAMER_BASE_LIBRARIES (Required is at least version "1.0")
-- Found MAVLink: /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/mavlink/include (found version "2.0")
-- catkin DISABLED
-- Checking for module 'protobuf'
-- Found protobuf, version 3.6.1
-- Gazebo version: 11.3
-- Found GStreamer: adding gst_camera_plugin
-- Found GStreamer: adding gst_video_stream_widget
-- Configuring done
-- Generating done
-- Build files have been written to: /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/build/px4_sitl_default/build_gazebo
[252/818] Performing build step for 'sitl_gazebo'
[29/125] Generating /home/ozan/Desktop...ebo/models/3DR_gps_mag/3DR_gps_mag.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/3DR_gps_mag/3DR_gps_mag.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/3DR_gps_mag/3DR_gps_mag.sdf
[31/125] Generating /home/ozan/Desktop...Tools/sitl_gazebo/models/boat/boat.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/boat/boat.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/boat/boat.sdf
[33/125] Generating /home/ozan/Desktop...Tools/sitl_gazebo/models/c920/c920.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/c920/c920.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/c920/c920.sdf
[34/125] Generating /home/ozan/Desktop...o/models/depth_camera/depth_camera.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/depth_camera/depth_camera.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/depth_camera/depth_camera.sdf
[35/125] Generating /home/ozan/Desktop..._gazebo/models/cloudship/cloudship.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/cloudship/cloudship.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/cloudship/cloudship.sdf
[36/125] Generating /home/ozan/Desktop...Tools/sitl_gazebo/models/iris/iris.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/iris/iris.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/iris/iris.sdf
[37/125] Generating /home/ozan/Desktop...ebo/models/matrice_100/matrice_100.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/matrice_100/matrice_100.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/matrice_100/matrice_100.sdf
[38/125] Generating /home/ozan/Desktop...models/mb1240-xl-ez4/mb1240-xl-ez4.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/mb1240-xl-ez4/mb1240-xl-ez4.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/mb1240-xl-ez4/mb1240-xl-ez4.sdf
[39/125] Generating /home/ozan/Desktop...sitl_gazebo/models/pixhawk/pixhawk.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/pixhawk/pixhawk.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/pixhawk/pixhawk.sdf
[40/125] Generating /home/ozan/Desktop...ols/sitl_gazebo/models/plane/plane.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/plane/plane.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/plane/plane.sdf
[41/125] Generating /home/ozan/Desktop...sitl_gazebo/models/px4flow/px4flow.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/px4flow/px4flow.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/px4flow/px4flow.sdf
[42/125] Generating /home/ozan/Desktop...tl_gazebo/models/r1_rover/r1_rover.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/r1_rover/r1_rover.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/r1_rover/r1_rover.sdf
[43/125] Generating /home/ozan/Desktop...Tools/sitl_gazebo/models/r200/r200.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/r200/r200.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/r200/r200.sdf
[44/125] Generating /home/ozan/Desktop...ols/sitl_gazebo/models/rover/rover.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/rover/rover.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/rover/rover.sdf
[45/125] Generating /home/ozan/Desktop...ols/sitl_gazebo/models/sf10a/sf10a.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/sf10a/sf10a.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/sf10a/sf10a.sdf
[46/125] Generating /home/ozan/Desktop...models/standard_vtol/standard_vtol.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/standard_vtol/standard_vtol.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/standard_vtol/standard_vtol.sdf
[47/125] Generating /home/ozan/Desktop...ndard_vtol_drop/standard_vtol_drop.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/standard_vtol_drop/standard_vtol_drop.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/standard_vtol_drop/standard_vtol_drop.sdf
[48/125] Generating /home/ozan/Desktop..._gazebo/models/tiltrotor/tiltrotor.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/tiltrotor/tiltrotor.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/tiltrotor/tiltrotor.sdf
[50/125] Generating /home/ozan/Desktop...o/models/typhoon_h480/typhoon_h480.sdf
/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/typhoon_h480/typhoon_h480.sdf.jinja -> /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models/typhoon_h480/typhoon_h480.sdf
[101/125] Building CXX object CMakeFil.../gazebo_gimbal_controller_plugin.cpp.o
In file included from /usr/include/string.h:495,
from /usr/include/tinyxml.h:42,
from /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/include/common.h:26,
from /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/src/gazebo_gimbal_controller_plugin.cpp:18:
In function ‘void* memcpy(void*, const void*, size_t)’,
inlined from ‘void mav_array_memcpy(void*, const void*, size_t)’ at /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/mavlink/include/mavlink/v2.0/common/../protocol.h:176:9,
inlined from ‘uint16_t mavlink_msg_gimbal_device_information_pack_chan(uint8_t, uint8_t, uint8_t, mavlink_message_t*, uint32_t, const char*, const char*, const char*, uint32_t, uint32_t, uint64_t, uint16_t, uint16_t, float, float, float, float, float, float)’ at /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/mavlink/include/mavlink/v2.0/common/./mavlink_msg_gimbal_device_information.h:209:21,
inlined from ‘void gazebo::GimbalControllerPlugin::SendGimbalDeviceInformation()’ at /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/src/gazebo_gimbal_controller_plugin.cpp:651:50:
/usr/include/x86_64-linux-gnu/bits/string_fortified.h:34:33: warning: ‘void* __builtin_memcpy(void*, const void*, long unsigned int)’ reading 32 bytes from a region of size 4 [-Wstringop-overflow=]
34 | return __builtin___memcpy_chk (__dest, __src, __len, __bos0 (__dest));
inlined from ‘uint16_t mavlink_msg_gimbal_device_information_pack_chan(uint8_t, uint8_t, uint8_t, mavlink_message_t*, uint32_t, const char*, const char*, const char*, uint32_t, uint32_t, uint64_t, uint16_t, uint16_t, float, float, float, float, float, float)’ at /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/mavlink/include/mavlink/v2.0/common/./mavlink_msg_gimbal_device_information.h:210:21,
/usr/include/x86_64-linux-gnu/bits/string_fortified.h:34:33: warning: ‘void* __builtin_memcpy(void*, const void*, long unsigned int)’ reading 32 bytes from a region of size 12 [-Wstringop-overflow=]
inlined from ‘uint16_t mavlink_msg_gimbal_device_information_pack_chan(uint8_t, uint8_t, uint8_t, mavlink_message_t*, uint32_t, const char*, const char*, const char*, uint32_t, uint32_t, uint64_t, uint16_t, uint16_t, float, float, float, float, float, float)’ at /home/ozan/Desktop/PX4_HITL/PX4-Autopilot/mavlink/include/mavlink/v2.0/common/./mavlink_msg_gimbal_device_information.h:211:21,
/usr/include/x86_64-linux-gnu/bits/string_fortified.h:34:33: warning: ‘void* __builtin_memcpy(void*, const void*, long unsigned int)’ reading 32 bytes from a region of size 1 [-Wstringop-overflow=]
[117/125] Building CXX object CMakeFiles/gazebo_user_camera_plugin.dir/include/[125/125] Linking CXX shared library libgazebo_opticalflow_plugin.so
[817/818] cd /home/ozan/Desktop/PX4_HI...L/PX4-Autopilot/build/px4_sitl_default
Not running simulation (DONT_RUN is set).
COMMAND-2:
ozan@Ozan-Ubuntu:~/Desktop/PX4_HITL/PX4-Autopilot$ source Tools/setup_gazebo.bash $(pwd) $(pwd)/build/px4_sitl_default
GAZEBO_PLUGIN_PATH :/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/build/px4_sitl_default/build_gazebo
GAZEBO_MODEL_PATH :/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/Tools/sitl_gazebo/models
LD_LIBRARY_PATH :/home/ozan/Desktop/PX4_HITL/PX4-Autopilot/build/px4_sitl_default/build_gazebo
COMMAND-3:
ozan@Ozan-Ubuntu:~/Desktop/PX4_HITL/PX4-Autopilot$ gazebo Tools/sitl_gazebo/worlds/hitl_standard_vtol.world
Opened serial device /dev/ttyACM0
My standard_vtol_hitl.sdf file settings are as below:
<plugin name='mavlink_interface' filename='libgazebo_mavlink_interface.so'>
<robotNamespace/>
<imuSubTopic>/imu</imuSubTopic>
<magSubTopic>/mag</magSubTopic>
<gpsSubTopic>/gps0</gpsSubTopic>
<baroSubTopic>/baro</baroSubTopic>
<mavlink_addr>INADDR_ANY</mavlink_addr>
<mavlink_udp_port>14560</mavlink_udp_port>
<mavlink_tcp_port>4560</mavlink_tcp_port>
<serialEnabled>1</serialEnabled>
<serialDevice>/dev/ttyACM0</serialDevice>
<baudRate>921600</baudRate>
<qgc_addr>INADDR_ANY</qgc_addr>
<qgc_udp_port>14550</qgc_udp_port>
<sdk_addr>INADDR_ANY</sdk_addr>
<sdk_udp_port>14540</sdk_udp_port>
<hil_mode>1</hil_mode>
<hil_state_level>0</hil_state_level>
<send_vision_estimation>0</send_vision_estimation>
<send_odometry>1</send_odometry>
<enable_lockstep>0</enable_lockstep>
<use_tcp>1</use_tcp>
