This weekend i was trying out the mission mode for the first time. When switching to mission mode the plane drops throttle to half and opens the flaps. However, this results in the plane flying to slow and eventually stalling. I tried upping the cruse speed from 15 to 20 m/s but that did not change the stalling.
Another problem i have is that the plane only turns with rudder during autonomous flight which in case when it is a steep turn also results in loss of control and the pilot has to take over in manual mode.
I had a somewhat similar issue. As soon as I switched into mission flight, the flaps would deploy no matter what, on-ground, or in the air near cruise velocity. The problem was actually pretty simple, the flap channel was reversed for auto-flight. It was a bit deceptive since the flaps would behave normally in manual and altitude hold modes, but I think that maybe the flaps are not in the control loop for altitude hold mode. All I did was reverse the flap output channel and the flap input channel, now it works as intended.
I have a similar problem as well. When I switch to Mission mode, the flaps engage and it remains in that state throughout the whole mission. My FW_FLAPS_LND_SCL is set to 100% but my FW_FLAPS_TO_SCL is set to 0% so I only expected my flaps to open for landing
@Geoffrey_DuBridge how did you reverse the flap output channel and the flap input channel?
