Hello , how can i use and configure the WIFI module ESP8266 with PX4 on Qground control
am using TELEM1 but i can’t see how to connect it on Qground
You need to associate with it over Wi-Fi and then you will automatically find your device.
Assuming you have the ESP 8266 flashed with the correct firmware you should find it with a default SSID of PIXRacer
Once you associate from the device where you are running QGC the rest is automatic
Have fun!
By the way you’re better off using the mRo
Wi-Fi since it has external antenna you’ll get much better range!
Application Settings ,
then,Comm Links ,
then, Add,
then,TCP
and you may need to set the address and port.
I have done already.
