Hello all,
I’m using a T-Motor P60A V2 4-in-1 ESC with a Cube Orange FC. The ESC supports DSHOT2400, while the Cube Orange only supports DSHOT 1200.
Unfortunately, the ESC doesn’t come with a manual or any related information, but everything I read online so far points to the ESC also supporting DSHOT1200.
I’ve done my PX4 parameter configuration according to this page:
https://docs.px4.io/main/en/peripherals/dshot.html
I can receive ESC_INFO and ESC_STATUS messages, but the frequency of the message oscillates a lot, between 0-10 Hz.
Additionally, running commands like dshot esc_info -m 2 doesn’t always show esc_info. Often, I get these two errors:
ERROR [dshot] Packet length mismatch (64 != 15)
ERROR [dshot] Checksum mismatch
, but when it works, I get the following:
nsh> dshot esc_info -m 2
INFO [dshot] ESC Type: #Tmotor_FG0_01#
INFO [dshot] MCU Serial Number: 86003c-000150-4b4b38-363020
INFO [dshot] Firmware version: 32.90
INFO [dshot] Rotation Direction: normal
INFO [dshot] 3D Mode: off
INFO [dshot] Low voltage Limit: off
INFO [dshot] Current Limit: unsupported
INFO [dshot] LED 0: off
INFO [dshot] LED 1: unsupported
INFO [dshot] LED 2: unsupported
INFO [dshot] LED 3: unsupported
Do you have any idea what I can do to solve this issue?
Thank you!
