I’m having trouble arming my ESC on a fixed wing. The ailerons work fine when armed but the ESC just gives a loud beeping.
QGC 3.0.2 with Flying Wing/Skywalker X5 1.5.1dev firmware.
The ESC is plugged into Main 3. From the firmware file, it looks like the output should be Main 4 but on that channel, no calibration happens, and no arming or motor spin.
The ESC obviously knows that the Pixhawk is armed because it only starts beeping when the arming switch is pressed. There’s no spin on the motor when the throttle increased, just loud beeping.
It works fine on APM Planner but I prefer the QGC interface.
Ideas would be much appreciated.
Tim
