16:37:54: Running steps for project qgroundcontrol…
16:37:54: Configuration unchanged, skipping qmake step.
16:37:54: Starting: “C:\Qt\Qt5.11.3\Tools\QtCreator\bin\jom.exe”
C:\Qt\Qt5.11.3\Tools\QtCreator\bin\jom.exe -f Makefile.Debug
C:\Qt\Qt5.11.3\5.11.3\msvc2015\bin\rcc.exe -name qgroundcontrol “C:\Users\Vamshi Goud\qgroundcontrol\qgroundcontrol.qrc” -pass 1 -o C:/Users/Vamshi Goud/build-qgroundcontrol-Desktop_Qt_5_11_3_MSVC2015_32bit-Debug/rcc/qrc_qgroundcontrol.cpp
C:\Qt\Qt5.11.3\5.11.3\msvc2015\bin\rcc.exe: File does not exist ‘Goud/build-qgroundcontrol-Desktop_Qt_5_11_3_MSVC2015_32bit-Debug/rcc/qrc_qgroundcontrol.cpp’
jom: C:\Users\Vamshi Goud\build-qgroundcontrol-Desktop_Qt_5_11_3_MSVC2015_32bit-Debug\Makefile.Debug [rcc\qrc_qgroundcontrol.obj] Error 1
C:\Qt\Qt5.11.3\5.11.3\msvc2015\bin\rcc.exe -name qgcresources “C:\Users\Vamshi Goud\qgroundcontrol\qgcresources.qrc” -pass 1 -o C:/Users/Vamshi Goud/build-qgroundcontrol-Desktop_Qt_5_11_3_MSVC2015_32bit-Debug/rcc/qrc_qgcresources.cpp
C:\Qt\Qt5.11.3\5.11.3\msvc2015\bin\rcc.exe: File does not exist ‘Goud/build-qgroundcontrol-Desktop_Qt_5_11_3_MSVC2015_32bit-Debug/rcc/qrc_qgcresources.cpp’
jom: C:\Users\Vamshi Goud\build-qgroundcontrol-Desktop_Qt_5_11_3_MSVC2015_32bit-Debug\Makefile.Debug [rcc\qrc_qgcresources.obj] Error 1
jom: C:\Users\Vamshi Goud\build-qgroundcontrol-Desktop_Qt_5_11_3_MSVC2015_32bit-Debug\Makefile [debug] Error 2
16:37:59: The process “C:\Qt\Qt5.11.3\Tools\QtCreator\bin\jom.exe” exited with code 2.
Error while building/deploying project qgroundcontrol (kit: Desktop Qt 5.11.3 MSVC2015 32bit)
When executing step “Make”
16:37:59: Elapsed time: 00:04.
Please help me with this
please help me with this when am trying to compile qgroundcontrol.pro in qtcreator 5.11.3 and i used msvc 2015 32 bit and cloned qgroundcontrol using git clone https://github.com/mavlink/qgroundcontrol.git’’‘c1xx error: C1033: cannot open program database ‘C:\build-qgroundcontrol-Desktop_Qt_5_11_3_MSVC2015_32bit-Debug\obj\QGroundControl.vc.pdb’’’
Thanks in advance
Hi Guys , I need help understandinf what im missing here.
I run the Qgroundcontrol.pro at QT creator and errors pop out
Project ERROR: You need to set the ANDROID_NDK_ROOT environment variable to point to your Android NDK.
Could not read qmake configuration file E:/ProgramFiles/QT/5.12.10/android_x86/mkspecs/android-clang/qmake.conf.
Could not read qmake configuration file E:/ProgramFiles/QT/5.12.10/android_arm64_v8a/mkspecs/android-clang/qmake.conf.
Could not read qmake configuration file E:/ProgramFiles/QT/5.12.10/android_armv7/mkspecs/android-clang/qmake.conf.
Project MESSAGE: Qt version 5.12.10
Project MESSAGE: Windows build
Project MESSAGE: Debug flavor
Project MESSAGE: Using Default QtLocation headers
Project MESSAGE: Skipping support for Pairing
Project MESSAGE: Using MAVLink dialect ‘ardupilotmega’.
Project ERROR: MAVLink folder does not exist at ‘libs/mavlink/include/mavlink/v2.0’! Run ‘git submodule init && git submodule update’ on the command line.
[Inexact] Cannot read E:/2021project/qgroundcontrol-4.0.10/qgroundcontrol-4.0.10/user_config.pri: No such file or directory
