PX4 drone take its frame to be NED, while we prefer ENU frame in robotics.
But I am still confused in push mocap infor to vision_pose and send position setpoints to mavros/setpoint_raw/local and mavros/setpoint_position/local.
If I do
pub mocap infor in ENU to /mavros/vision_pose/pose ,
pusb reference position in NED, takeoff 1m means (0,0,-1), to mavros/setpoint_raw/local,
then, what I get is “INFO [commander] Disarmed by auto preflight disarming” in simulation. (edited)
Interestingly, if I do
pusb reference position in ENU, takeoff 1m means (0,0,1), to mavros/setpoint_raw/local or mavros/setpoint_position/local..
It does take off and hover in simulation.
Does mavros automatically accepts/publish infro in ENU, and transfer them into NED to NED? Does it mean, we do not need to brother?
Hi, Benja. Thanks so much for your reply. I read the links that sent by you.
Just to be sure:
In terms of setpoint_raw/local, should I leave coordinate_frame () empty when I pub commands in ENU, such that it will run position = ftf::transform_frame_enu_ned(position) in line 223?
But for setpoint_position/local , the message (geometry_msgs/PoseStamped) does not have a coordinate_frame for us to specify like mavros_msgs/PositionTarget for setpoint_raw/local. What should I do for using mavlink::common::MAV_FRAME in order to use ENU? Or It is set to be the ENU frame by default?
Thanks for your message.
I just tested both in gazebo simulation.
From the simulation results, we can send commands in ENU to them .
I will test them in real experiments soon.
