I’m porting the robotis dynamixel servo to PX4 from Ardupilot. After looking at how it was setup (very similar to frsky smart port telemetry), i did most of the setup in my module, but then i noticed that the uart signal should be inverted (0v = High, 3.3V = low).
I implemented the inversion the same way it was done on frsky telem
ioctl(uart, TIOCSINVERT, invert ? (SER_INVERT_ENABLED_RX | SER_INVERT_ENABLED_TX) : 0)
but when looking at the uart signal from the oscilloscope it s not inverted at all.
Can you help me figure out why it s not inverted ?
here is the full setup of the uart on /dev/ttyS2
/* Open UART */
const int uart = open(uart_name, O_RDWR | O_NOCTTY | O_NONBLOCK);
if (uart < 0) {
PX4_ERR("Error opening port: %s (%i)", uart_name, errno);
PX4_INFO("UART port error");
return -1;
PX4_INFO("UART open success");
/* Back up the original UART configuration to restore it after exit */
int termios_state;
if ((termios_state = tcgetattr(uart, uart_config_original)) < 0) {
PX4_ERR("tcgetattr %s: %d\n", uart_name, termios_state);
close(uart);
return -1;
/* Fill the struct for the new configuration */
tcgetattr(uart, uart_config);
/* Disable output post-processing */
uart_config->c_oflag &= ~OPOST;
uart_config->c_cflag |= (CLOCAL | CREAD); /* ignore modem controls */
uart_config->c_cflag &= ~CSIZE;
uart_config->c_cflag |= CS8; /* 8-bit characters */
uart_config->c_cflag &= ~PARENB; /* no parity bit */
uart_config->c_cflag &= ~CSTOPB; /* only need 1 stop bit */
uart_config->c_cflag &= ~CRTSCTS; /* no hardware flowcontrol */
/* setup for non-canonical mode */
uart_config->c_iflag &= ~(IGNBRK | BRKINT | PARMRK | ISTRIP | INLCR | IGNCR | ICRNL | IXON);
uart_config->c_lflag &= ~(ECHO | ECHONL | ICANON | ISIG | IEXTEN);
/* Set baud rate */
// todo : dynamixel works on 9600 57600(default) 115200 1M 2M 3M 4M 4.5M
const speed_t uart_speed = B57600;
if (cfsetispeed(uart_config, uart_speed) < 0 || cfsetospeed(uart_config, uart_speed) < 0) {
PX4_ERR("%s: %d (cfsetispeed, cfsetospeed)\n", uart_name, termios_state);
close(uart);
return -1;
if ((termios_state = tcsetattr(uart, TCSANOW, uart_config)) < 0) {
PX4_ERR("%s (tcsetattr)\n", uart_name);
close(uart);
return -1;
set_uart_single_wire(uart, true); // ioctl(uart, TIOCSSINGLEWIRE, single_wire ? (SER_SINGLEWIRE_ENABLED | SER_SINGLEWIRE_PUSHPULL | SER_SINGLEWIRE_PULLDOWN) : 0)
set_uart_invert(uart, true); // ioctl(uart, TIOCSINVERT, invert ? (SER_INVERT_ENABLED_RX | SER_INVERT_ENABLED_TX) : 0)
return uart;
