Documentation of parameters
I am working on a tilt rotor (4 tilt + 2 normal) VTOL with aileron and v tail and i am new to pixhawk. There is no ready to use airframe available on the PX4 github.
I am using 13030_generic_vtol_quad_tiltrotor and trying to modify it.
But i am not aware of all parameters description. Like,
param set-default CA_ROTOR3_KM -0.05
param set-default CA_SV_CS0_TYPE 1
param set-default CA_SV_CS0_TRQ_R -0.5
Is there any documentation available where the description of all usable parameter are mentioned?
Thanks in advance for you time.
Yes, please check out the parameter reference documentation:
Thank you, this helps a lot.
