Hi everyone,
I am trying to build a custom firmware for Cube Orange (after being unable to upload regular firmware from QGC).
I followed all instructions and tried building a code, however I can’t find “make” command for Cube Orange. On this page Building the Code · PX4 Developer Guide I see * Cube Orange: make hex_cube-orange as a command, however nothing happens. I tried other commands and it builds the file.
This: https://github.com/mavlink/qgroundcontrol/pull/9221 will fix the firmware not found error. But that doesn’t quite seem to be the problem you are having. That seems more like a driver problem. Try uninstalling all the PX4 UAV drivers and then reinstall daily to get the drivers installed again.
Depending on what commit of PX4 you’re using, the initial implementation place the Orange Cube board config at hex/cube-orange, but it is now (at the request of Phillip) renamed to cubepilot/cubeorange. So try make cubepilot_cubeorange. You can see all supported targets under the boards/ folder.
