Controll Multi-Drones by keyboard using mavsdk-python
Hi everyone,
Hi everyone, I have written a python script that controls a drone with a keyboard. But when I upgrade to control 2 drones at the same time by connecting 2 simulated drones and giving control commands to both drones, it means that 2 drones will have to move the same but only one moves. Hope you give me advice.
This is my code below.
import asyncio
import random
from mavsdk import System
import KeyPressModule as kp
# Test set of manual inputs. Format: [roll, pitch, throttle, yaw]
kp.init()
drone1 = System()
drone2 = System()
roll, pitch, throttle, yaw = 0, 0, 0.5, 0
async def getKeyboardInput(my_drone):
    global roll, pitch, throttle, yaw
    while True:
        value = 1
        if kp.getKey("LEFT"):
            pitch = -value
        elif kp.getKey("RIGHT"):
            pitch = value
        if kp.getKey("UP"):
            roll = value
        elif kp.getKey("DOWN"):
            roll = -value
        if kp.getKey("w"):
            throttle = value
        elif kp.getKey("s"):
            throttle = 0
        if kp.getKey("a"):
            yaw = -value
        elif kp.getKey("d"):
            yaw = value
        elif kp.getKey("i"):
            asyncio.ensure_future(print_flight_mode(my_drone))
        elif kp.getKey("q") and my_drone.telemetry.landed_state():
            await my_drone.action.arm()
        elif kp.getKey("l") and my_drone.telemetry.in_air():
            await my_drone.action.land()
        # print(roll, pitch, throttle, yaw)
        await asyncio.sleep(0.1)
async def print_flight_mode(my_drone):
    async for flight_mode in my_drone.telemetry.flight_mode():
        print("FlightMode:", flight_mode)
        # return flight_mode
async def manual_control_drone(my_drone):
    while True:
        await my_drone.manual_control.set_manual_control_input(roll, pitch, throttle, yaw)
async def run_drone1():
    asyncio.ensure_future(getKeyboardInput(drone1))
    await drone1.connect(system_address="udp://:14540")
    # This waits till a mavlink based drone is connected
    print("Waiting for drone to connect...")
    async for state in drone1.core.connection_state():
        if state.is_connected:
            print(f"-- Connected to drone!")
            break
    # Checking if Global Position Estimate is ok
    async for health in drone1.telemetry.health():
        if health.is_global_position_ok and health.is_home_position_ok:
            print("-- Global position state is good enough for flying.")
            break
    asyncio.ensure_future(manual_control_drone(drone1))
async def run_drone2():
    asyncio.ensure_future(getKeyboardInput(drone2))
    await drone2.connect(system_address="udp://:14541")
    async for state in drone2.core.connection_state():
            break
    async for health in drone2.telemetry.health():
            break
    asyncio.ensure_future(manual_control_drone(drone2))
async def run():
    """Main function to connect to the drone and input manual controls"""
    await asyncio.gather(run_drone1(), run_drone2())
if __name__ == "__main__":
    # Start the main function
    asyncio.ensure_future(run())
    # Runs the event loop until the program is canceled with e.g. CTRL-C
    asyncio.get_event_loop().run_forever()
This is not correct. You need to manually run mavsdk_server_bin twice with different arguments.
So, for me, this would be:
.local/lib/python3.10/site-packages/mavsdk/bin/mavsdk_server udp://:14540 -p 50060
And:
.local/lib/python3.10/site-packages/mavsdk/bin/mavsdk_server udp://:14541 -p 50061
And then you connect to the two using:
    drone1 = System(mavsdk_server_address="localhost", port=50060)
    await drone1.connect()
    drone2 = System(mavsdk_server_address="localhost", port=50061)
    await drone2.connect()
thank you very much, i will do it.
I have tried it and succeeded. Thank you very much
Hi, My project is almost done and thank you for your enthusiastic support. There is an extra part that is about mavsdk_server when I have to simulate 3 drones and connect them with python code I have to run 3 more terminals to run mavsdk_server and that is quite inconvenient. I wonder how can my program connect to multi-drones like QGroundcontrol or is there a way to connect multiple drones automatically?!
If you don’t want multiple terminals, you can just launch them in the same terminal by adding & at the end of each line (that’s space and then ampersant). That way it’s launched in the background.
Alternatively, you can use a script to launch them all (also with ampersand), your you can use screen or tmux instances and launch it in there and then detach, and you can also script that.
