MAVSDK multiple drones problem
Hi everyone. Im new to simulations and trying to figure out how to create and control multiple drones in PX4 + gazebo classic using Python MAVSDK. In single drone simulations everything is working ok.
Im starting multiple simulations by executing
Tools/simulation/gazebo-classic/sitl_multiple_run.sh -m iris -n 2
Next i`m running following script but only one drone is taking off. Tried everything and can make this work correctly. Thanks for any help
import asyncio
from mavsdk import System
async def connect_drone(port):
    drone = System()
    await drone.connect(system_address=f"udp://:{port}")
    async for state in drone.core.connection_state():
        if state.is_connected:
            print(f"Connected to drone on port {port}")
            break
    async for health in drone.telemetry.health():
        if health.is_global_position_ok and health.is_home_position_ok:
            print(f"Drone on port {port} is ready to arm")
            break
    id = await drone.info.get_identification()
    print(f"UUID of drone : {id}")
    return drone
async def run():
    ports = [14541, 14542]
    drones = await asyncio.gather(*(connect_drone(port) for port in ports))
    # Arm all drones
    await asyncio.gather(*(d.action.arm() for d in drones))
    print("All drones armed")
    # Take off
    await asyncio.gather(*(d.action.takeoff() for d in drones))
    print("All drones taking off")
    await asyncio.sleep(10)
 asyncio.run(run())
PS running on Windows11 with WSL2 and Ubuntu 20.04
I am actually working on the same problem. But today i figured that if we sequentially run them we can move them one after another - But my requirement is to be able to control multiple together even groups together.
I’m running on windows 11 with WSL and ubuntu 24.04.
Code:
import asyncio
from mavsdk.offboard import OffboardError, VelocityNedYaw
async def run_mission(port: int):
    drone = System()
    print(f"Connecting to drone at port {port}...")
    # Wait until the drone is connected.
            print(f"Drone on port {port} connected!")
            break
    # Wait until global and home positions are set.
            print(f"Drone on port {port} is healthy and ready!")
            break
    print(f"Arming drone on port {port}...")
    await drone.action.arm()
    print(f"Taking off drone on port {port}...")
    await drone.action.takeoff()
    await asyncio.sleep(10)  # Wait for takeoff altitude
    print(f"Setting initial offboard setpoint (zero velocity) on port {port}...")
    await drone.offboard.set_velocity_ned(VelocityNedYaw(0.0, 0.0, 0.0, 0.0))
    print(f"Starting offboard mode on port {port}...")
    try:
        await drone.offboard.start()
    except OffboardError as error:
        print(f"Failed to start offboard mode on port {port}: {error._result.result}")
        print("Disarming drone...")
        await drone.action.disarm()
        return
    print(f"Sending velocity command: move forward at 1 m/s on port {port}...")
    await drone.offboard.set_velocity_ned(VelocityNedYaw(1.0, 0.0, 0.0, 0.0))
    print(f"Stopping drone on port {port}...")
    await asyncio.sleep(5)
    print(f"Landing drone on port {port}...")
    await drone.action.land()
    print(f"Disarming drone on port {port}...")
    print(f"Mission sequence for drone on port {port} completed.")
async def main():
    # Run mission for the drone on port 14541 first.
    await run_mission(14541)
    print("Waiting 5 seconds before starting mission for the next drone...")
    # Then run mission for the drone on port 14540.
    await run_mission(14540)
if __name__ == "__main__":
    asyncio.run(main())
I was able to find solution. I used gz harmonic and Ubuntu 22.04 on WSL
We can use different ports for System(). And it works
async def connect_drone(system_address, i):
    drone = System(port=50051 + i)
    await drone.connect(system_address=system_address)
    print(f"[{system_address}] Waiting for connection...")
            print(f"[{system_address}] Drone connected!")
            break
    print(f"[{system_address}] Waiting for global position estimate...")
            print(f"[{system_address}] Global position is OK.")
            break
    return drone
async def arm_and_takeoff(drone, system_address, height):
    print(f"[{system_address}] Arming...")
    print(f"[{system_address}] Taking off...")
    await drone.action.set_takeoff_altitude(height)
    async for position in drone.telemetry.position():
        current = position.relative_altitude_m
        if abs(current - height) < threshold:
            break
    print(f"[{system_address}] Height {height} reached...")
async def land_and_disarm(drone, system_address):
        if abs(current) < threshold:
            break
    print(f"[{system_address}] Landed...")
async def main():
    # Addresses for PX4 SITL instances
    address_1 = "udp://:14541"
    address_2 = "udp://:14542"
    # Connect to both drones
    drone1_task = connect_drone(address_1, 0)
    drone2_task = connect_drone(address_2, 1)
    drone1, drone2 = await asyncio.gather(drone1_task, drone2_task)
    # Arm and take off both drones concurrently
        arm_and_takeoff(drone1, address_1, 5),
        arm_and_takeoff(drone2, address_2, 10)
        land_and_disarm(drone1, address_1),
        land_and_disarm(drone2, address_2),
Thank you so much!! This works- i have been struggling with this since 3 days and even started trying QGroundControl.
Thanks again for your help!
I also was trying everything for several days) glad i could help
This worked for me as well! Thank you @skiff2011
After several sleepless nights I found this, My heartiest Thank you. I can assure you even chatgpt, sonet were not able to solve it.
