Hi everyone, it’s possible to connect 2 drones with gazeblo-classic on QGC, using python? Because i’ve tryied the basic connection model and it doesn’t work.
Yes, and it doesn’t work… I’m trying to write down 2 python script to control a mission for each drone:
for drone 1:
import asyncio
from mavsdk import System
from mavsdk.mission import (MissionItem, MissionPlan)
async def run():
drone = System(sysid=2)
await drone.connect(system_address="udp://:14541")
await drone.action.arm()
mission_items = []
#mission_items.append(MissionItem(47.398039859999997, 8.5455725400000002, 2.5, 5,
# True, float('nan'), float('nan'), MissionItem.CameraAction.NONE, float('nan'), float('nan'),float('nan'),float('nan'),float('nan')))
mission_items.append(MissionItem(47.3978133, 8.5456344, 2.5, 5,
mission_items.append(MissionItem(47.3977222, 8.5457436, 2.5, 5,
mission_items.append(MissionItem(47.3976182, 8.5456850, 2.5, 5,
mission_items.append(MissionItem(47.3977494, 8.5455343, 2.5, 5,
mission_plan = MissionPlan(mission_items)
print(drone)
await drone.mission.upload_mission(mission_plan)
await drone.mission.start_mission()
asyncio.get_event_loop().run_until_complete(run())
for drone 2:
import asyncio
async def run():
await drone.connect(system_address="udp://:14542")
sysid = drone._sysid
compid = drone._compid
print("sysid: {sysid}")
print("compid: {compid}")
mission_items = []
# ... aggiungi altri waypoint come necessario
print(drone)
@Jaeyoung-Lim Many thanks, solved it. I think that the problem was the installation of Gazebo-classic, i just uninstall and re-install it again and it works !
