That’s usually an indication that it’s not getting a PWM signal from the FC. Try using Vertical Technology’s Delta Quad airframe and connect wires per diagram. Of course, remove prop/s before testing.
HI
My aircraft is Generic delta vtol .
I am sure that everything is connected correctly.
Also, if you do arming, there is no problem with your movements.
