Connecting ESCs with different max voltages to FMU PWM out pins
Hi, I am trying to control 4 ESCs with a Pixhawk 4 and power management board (PMB). Two of the ESCs have a max voltage of 26V, and the other two ESCs have a max voltage of 60V, since the two pairs of ESCs are being used to control two pairs of different sized motors. I am using a 48V to supply power to the PMB. My plan is to connect all four ESCs to the FMU PWM out pins on the PMB. Would this work, since the ESCs have different voltage requirements? I purchased a voltage regulator for the lower voltage ESCs, but I’m trying to figure out if the PMB takes care of that. Thank you
