Are there any reasons not to use direct USB connection between the companion computer and the flight controller? Documentation advises to use TELEM2 for this purpose, but is there something I need to consider before using USB apart from remove arming check for USB connection?
@j_p It is the wrong connector to use in flight. It is not safe to fly while relying on a micro USB
Do you mean USB as communication media, or micro USB as a connector? If the latter - I plan to use JST-GH based USB port on Holybro Pixhawk.
