During forward transition, the altitude is held constant as defined in the Take-off WP. However, I want it keep climbing to the altitude defined in the waypoint which is coming after “VTOL Take-off”.
May someone guide me where in the code I need to do this modification? I tried applying altitude offsets at a few places, but another logic overrides my offsets, and keeps the altitude constant during forward transition.
_velocity_setpoint(2) is the value which commands the thrust. Maybe its enough to set it to NAN, maybe you need to fill it with another value (not 100% sure there…)
This is the value should be set for climbing transition (negative is upwards).
However this function is entered in both forward and backward transitions. Therefore it is climbing during back transition as well. What is the flag which determines that aircraft is forward or back transitioning? I will keep the vertical velocity setpoint as zero during back transition.
hi,
i changed the _velocity_setpoint(2) hard coded to -3 just to see it works - it works well bu during the climb the plane seems to be drifting - can anyone give an advice about it?
Speaking from experience, don’t forget to keep in mind that climbing while accelerating creates a very large power draw on the system. Usually, aircraft have the power to climb or accelerate, but not both at the same time. Keep an eye on thrust values, and ESC temps. If your vehicle doesn’t have an extraordinarily high power to weight ratio, you may be risking a catastrophic failure.
