[BUG] SITL Gazebo, Reset world error
I am having the following error when I reset the iris world in gazebo.
Msg] Waiting for master.
[Msg] Publicized address: 129.175.4.102
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/iris/motors, deleting message. This warning is printed only once.
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/iris/motor_speed/0, deleting message. This warning is printed only once.
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/iris_1/motors, deleting message. This warning is printed only once.
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/iris_1/motor_speed/0, deleting message. This warning is printed only once.
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/iris_1/motor_speed/1, deleting message. This warning is printed only once.
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/iris_1/motor_speed/2, deleting message. This warning is printed only once.
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/iris_1/motor_speed/3, deleting message. This warning is printed only once.
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/iris_2/motor_speed/1, deleting message. This warning is printed only once.
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/iris_2/motor_speed/2, deleting message. This warning is printed only once.
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/iris_2/motor_speed/3, deleting message. This warning is printed only once.
[Err] [gazebo_motor_model.cpp:191] Aliasing on motor [0] might occur. Consider making smaller simulation time steps or raising the rotor_velocity_slowdown_sim_ param.
[Err] [gazebo_motor_model.cpp:191] Aliasing on motor [1] might occur. Consider making smaller simulation time steps or raising the rotor_velocity_slowdown_sim_ param.
[Err] [gazebo_motor_model.cpp:191] Aliasing on motor [2] might occur. Consider making smaller simulation time steps or raising the rotor_velocity_slowdown_sim_ param.
[Err] [gazebo_motor_model.cpp:191] Aliasing on motor [3] might occur. Consider making smaller simulation time steps or raising the rotor_velocity_slowdown_sim_ param.
gzserver: /meta/Spider-pig/Firmware/Tools/sitl_gazebo/src/gazebo_imu_plugin.cpp:194: void gazebo::GazeboImuPlugin::addNoise(Eigen::Vector3d*, Eigen::Vector3d*, double): Assertion `dt > 0.0’ failed.
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/user_camera/pose, deleting message. This warning is printed only once.
after a while gazebo freeze and terminate
I don’t think reseting the world is currently supported by the way PX4 interacts with Gazebo.
And you can see where it goes wrong:
/meta/Spider-pig/Firmware/Tools/sitl_gazebo/src/gazebo_imu_plugin.cpp:194: void gazebo::GazeboImuPlugin::addNoise(Eigen::Vector3d*, Eigen::Vector3d*, double): Assertion `dt > 0.0' failed.
Thanks for your answer, @JulianOes
In fact, I am looking more specifically to reset the model position, I found that it is possible using the View panel in gazebo.
I have tried to write several code to reset the mode automatically from the outside even being inspired by the source code of gazebo itself. However, the code I have written does not do anything.
I do not know if you have an idea why it does not working. Should the code be implemented as a plugin?? or I missed something ?
      /*  C++ Standard library include */
# include <cstdlib>
# include <string>
# include <future>
# include <chrono>
# include <thread>
# include <vector>
/*  locale defined include */
# include "gazebo.hh"
int main(int argc, char* argv[])
  gazebo::transport::NodePtr node(new gazebo::transport::Node());
  /*  start resetting the world  */
  gazebo::transport::PublisherPtr reset_pub;
  gazebo::transport::PublisherPtr  userCmdPub;
  node->Init("iris.world");
  node->GetTopicNamespace();
  //  ~/world_control
  reset_pub = node->Advertise<gazebo::msgs::WorldControl>("~/world_control");
  userCmdPub = node->Advertise<gazebo::msgs::UserCmd>("~/user_cmd");
  gazebo::msgs::WorldControl msg;
  //  w_ctrl.reset(); //->set_all(true); //I believe this is equal to indicating a world reset
  msg.mutable_reset()->set_all(false);
  msg.mutable_reset()->set_time_only(false);
  msg.mutable_reset()->set_model_only(true);
  gazebo::msgs::UserCmd userCmdMsg;
  userCmdMsg.set_description("Reset models");
  userCmdMsg.set_type(gazebo::msgs::UserCmd::WORLD_CONTROL);
  userCmdMsg.mutable_world_control()->CopyFrom(msg);
  userCmdPub->Publish(userCmdMsg);
  reset_pub->Publish(msg);
I would like to reset the model only after the quadcopters have landed. No reset model position have been preformed if the quadcopters where flying.
Best regards,
This seems like a separate issue that. I would recommend you create a new post here, or over at the Gazebo forums:
http://answers.gazebosim.org/questions/
