Describe the bug
I’m trying to use the typhoon_h480 with SITL in gazebo. At first, I created a world with a 3DR Iris model and run no_sim=1 make px4_sitl_default gazebo
and then roslaunch gazebo_ros empty_world.launch world_name:=$(pwd)/Tools/sitl_gazebo/worlds/typhoon.world
. Everything works fine, I can control the UAV correctly. Now I made the same steps, but I changed the drone to typhoon_h480. When I launch the world I receive several warnings regarding ‘primary EKF changed’ and ’ baro hgt timeout - reset to baro’.
To Reproduce
Steps to reproduce the behavior:
Create a simple world in gazebo with typhoon_h480.
Run `no_sim=1 make px4_sitl_default gazebo` and `roslaunch gazebo_ros empty_world.launch world_name:=$(pwd)/Tools/sitl_gazebo/worlds/typhoon.world`
Expected behavior
Should be able to takeoff and control the UAV.
Log Files and Screenshots
[0/4] Performing build step for 'sitl_gazebo'
ninja: no work to do.
[3/4] cd /home/guilherme/src/Firmware/...me/src/Firmware/build/px4_sitl_default
SITL ARGS
sitl_bin: /home/guilherme/src/Firmware/build/px4_sitl_default/bin/px4
debugger: none
program: gazebo
model: none
world: none
src_path: /home/guilherme/src/Firmware
build_path: /home/guilherme/src/Firmware/build/px4_sitl_default
SITL COMMAND: "/home/guilherme/src/Firmware/build/px4_sitl_default/bin/px4" "/home/guilherme/src/Firmware/build/px4_sitl_default"/etc -s etc/init.d-posix/rcS -t "/home/guilherme/src/Firmware"/test_data
INFO [px4] Creating symlink /home/guilherme/src/Firmware/build/px4_sitl_default/etc -> /home/guilherme/src/Firmware/build/px4_sitl_default/tmp/rootfs/etc
______ __ __ ___
| ___ \ \ \ / / / |
| |_/ / \ V / / /| |
| __/ / \ / /_| |
| | / /^\ \ \___ |
\_| \/ \/ |_/
px4 starting.
Info: found model autostart file as SYS_AUTOSTART=10016
INFO [param] selected parameter default file eeprom/parameters_10016
INFO [parameters] BSON document size 486 bytes, decoded 486 bytes
[param] Loaded: eeprom/parameters_10016
INFO [dataman] Unknown restart, data manager file './dataman' size is 11798680 bytes
PX4 SIM HOST: localhost
INFO [simulator] Waiting for simulator to accept connection on TCP port 4560
INFO [simulator] Simulator connected on TCP port 4560.
INFO [commander] LED: open /dev/led0 failed (22)
INFO [init] Mixer: etc/mixers/quad_w.main.mix on /dev/pwm_output0
INFO [ekf2] starting instance 0, IMU:0 (1310988), MAG:0 (197388)
INFO [mavlink] mode: Normal, data rate: 4000000 B/s on udp port 18570 remote port 14550
INFO [ekf2] starting instance 1, IMU:1 (1310996), MAG:0 (197388)
INFO [ekf2] starting instance 2, IMU:2 (1311004), MAG:0 (197388)
INFO [ekf2] starting instance 3, IMU:0 (1310988), MAG:1 (197644)
INFO [ekf2] starting instance 4, IMU:1 (1310996), MAG:1 (197644)
INFO [ekf2] starting instance 5, IMU:2 (1311004), MAG:1 (197644)
INFO [mavlink] mode: Onboard, data rate: 4000 B/s on udp port 14280 remote port 14030
INFO [mavlink] mode: Gimbal, data rate: 400000 B/s on udp port 13030 remote port 13280
INFO [logger] [logger] ./log/2022-11-15/21_47_19.ulg
INFO [logger] Opened full log file: ./log/2022-11-15/21_47_19.ulg
INFO [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
pxh> INFO [mavlink] partner IP: 127.0.0.1
INFO [ecl/EKF] reset position to last known position
INFO [ecl/EKF] reset velocity to zero
INFO [ecl/EKF] INFO [ecl/EKF] reset position to last known position
INFO INFO [ecl/EKF] GPS checks passed
INFO [ecl/EKF] 7016000: EKF aligned, (baro hgt, IMU buf: 12, OBS buf: 9)
INFO [ecl/EKF] 7024000: EKF aligned, (baro hgt, IMU buf: 12, OBS buf: 9)
INFO [ecl/EKF] 7096000: EKF aligned, (baro hgt, IMU buf: 12, OBS buf: 9)
INFO [ecl/EKF] reset position to GPS
INFO [ecl/EKF] reset velocity to GPS
INFO [ecl/EKF] starting GPS fusion
INFO [ecl/EKF] 7100000: EKF aligned, (baro hgt, IMU buf: 12, OBS buf: 9)
INFO [ecl/EKF] 7104000: EKF aligned, (baro hgt, IMU buf: 12, OBS buf: 9)
INFO INFO [ecl/EKF] reset position to GPS
[ecl/EKF] INFO reset velocity to GPS[ecl/EKF] reset velocity to GPS
INFO INFO [ecl/EKF] [ecl/EKF] reset velocity to GPS
INFO starting GPS fusion[ecl/EKF] starting GPS fusion
INFO [tone_alarm] home set
INFO [tone_alarm] notify negative
WARN [ekf2] primary EKF changed 0 (filter fault) -> 1
WARN [ekf2] primary EKF changed 1 (filter fault) -> 2
WARN [ekf2] primary EKF changed 2 (filter fault) -> 1
WARN [ecl/EKF] baro hgt timeout - reset to baro
WARN [ecl/EKF] WARN [ecl/EKF] baro hgt timeout - reset to baro
WARN [ekf2] primary EKF changed 1 (filter fault) -> 4
WARN [ekf2] primary EKF changed 4 (filter fault) -> 0
I’m not sure what is causing this behavior. Any help is appreciated.
